SDA CRS as center
I'm setting up a 5.1 HT using SDA CRS as fronts and rears. I have 2 pairs CRS for surrounds, but only one odd CRS that I want to use as the center speaker. How should I wire the center CRS so both drivers and tweeters produce sound? Has anyone tried a single SDA as a center? Will the CRS serve as a good center?
Post edited by Libertyc on
Probably need gidrah or raife to comment on the internal wiring changes. Polk CS my also be able to help.
Is shielding a concern? If yes, you can buy the bucking magnets through Polk CS.More later,
Tour...
Vox Copuli
Some historical references from the forum archives:
CRS+ Forum Thread #1
CRS+ Forum Thread #2Originally posted by Libertyc
I used a single CRS+ as a center for about a month, then I went to a pair of CRS+s. I used the dual CRS+s for a long time until I replaced them with two LSiC centers. My decision to replace the CRS+s was strictly a cosmetic decision. I just did not like the bulky look of the CRS+s above my television.
When I used a single CRS speaker, I disconnected the SDA driver and wired it in parallel with the stereo driver. You can also wire the drivers in series, but I found that wiring in series made the impedance too high and greatly diminished the sound volume of the speaker.
If I understand your post correctly, you have the earlier version of the CRS with two tweeters. I can email you a crossover schematic if you need one.Proud and loyal citizen of the Digital Domain and Solid State Country! -
See, I told you raife could help.
raife,
Going to have to start charging you for these referrals...More later,
Tour...
Vox Copuli
Yeah, I'll start charging a consulting fee and give you a kickback.:DProud and loyal citizen of the Digital Domain and Solid State Country!
