Can you see the smoke?
nooshinjohn
I have been on hold now with the worst company on the planet, COMCAST for over 30 minutes now:mad::mad:....
Last week, I had some work done in the yard that exposed my cable. Appearently, when I had it installed a few years ago, they never BURIED the CABLE! Tonight, my lawnmower chopped it to ribbons and tangled it around the blade. This is now my second attempt to get through after the first was disconnected.:mad::mad:
So the question is not whether or not I keep Comcast (they are dead to me now) burt who do I go with now? My only choices are Direct TV or Dish Network.:cool: Any preferences?
Post edited by nooshinjohn on
http://www.retailmenot.com/out_frame/1703619
You know where I stand on this. Check out the savings above. Been a happy customer for 10 years. 'nuff said.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I have Direct TV and have been happy for over 10 years so... Most times they will give like free channels and stuff.
Its up to you though. Crappy if it rains...kinda cuts out...but thats with all sattiliteReceiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
PerfectCreature wrote: »I have Direct TV and have been happy for over 10 years so... Most times they will give like free channels and stuff.
On another thread you said you were 20 years old. You say you've had Direct TV for over 10 years. So, since you were 8 or 9 years old? Mowed a lot of lawns or something to pay for it? Just curious. :D
Chris -
Just got off the phone (finally!!!) They are going to get a tech out here to fix it and cover a couple months of service, but I don't really think I care at this point. I will be calling Direct TV in the morning.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
So it's Comcast's fault you did some work and exposed your cable coax feed line and then sucked it up in your lawn mower? It sounds like they are really trying on the CS end of things. I don't have a real fondness for them either, however this sounds more in their favor than yours.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Hello
I've been a DirecTv customer since pretty much day one when they launched.
I made the move to HD a couple of years ago and have been very very happy with the channels, reception, and reliability of the system. Customer support, ehhh.....
But, I did do quite a bit of prep work before they came to do the install. I made a bracket to mount the dish on an old C-band pole. Heres the thread about it:
http://www.dbstalk.com/showthread.php?t=147406
I ran all the cables myself, and I also bought my own receivers from weaknees.com, two HR-21 Pro's. Now about the receivers, I've been "punished" for buying my own receivers and not getting the free ones from DirecTv....but I sit back and laugh at all the issues people have these other model receivers. Yes, some do have good luck but theres alot of problems and I've had zero issues with these receivers....They are fast, stable, and error free...
So, there you go...Testing
Testing
Testing -
They confirmed that there was a request made to bury the cable but it was never done. I had some work done on the side of the house on my central air system and they must have lifted it from under the grass. I have not been able to get around to cutting the grass for a couple weeks and did not see the cable.
Tracing the cable all the way back to the feed confirmed the cable was never buried. It was just covered by weeds in the vacant lot next door where they tossed it when they did the install.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I've had DirecTV for a while and have been pretty happy with them. I think if you sign up using a current customers account number both you and that person get $100. Worth checking into maybe.Things work out best for those who make the best of the way things work out.-John Wooden
Fios Baby!!
I wish it were available here, but in Corn Country we are lucky to have a toilet that flushes.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
FIOS is the best from a scan rate perspective, I would say direct is second but not cheap.
DIsh might have to turn off their DVR service or something like that.
Just can not do cable.Speakers: SDA-1C (most all the goodies)
I don't know what version of DVR HD DTV has now. But my HR20-100 and HR20-700 are stable and solid for the past 3 years. The latest HD-DVR might have SVM, which has 2 tuners but allow you to run one cable per box.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Comcast (along with all the other cable providers I've dealt with) are notorious for burying their drops no deeper than a few inches. They consider it cheaper to repair ther drops than to spend the money to bury them at a normal drop depth.
I'm sure if it would've been buried at the normal 12" plus for a drop wire he would've never exposed it.
To the OP. I've been with Directv for 10 yrs and I'll never go back to a cable provider.My equipment sig felt inadequate and deleted itself. -
I had DirectTV for 6 years without an issue.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I've used directv and dish and prefer directv. I despise comcast, although they're the only game in town for high speed internet, so I've bitten the bullet on that. I will say that I'm not terribly pleased with my dvr box (it's slow), but everything else is great. It rarely has reception problems (like never... Ok, maybe once).
P.S. I've heard that new company xfinity is pretty good. -
Love our DTV and will never go to cable nor dish network.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I wont comment on DTV since we're happy with DN, and it's cheaper, so we see no valid reason to change just to pay more.
ATT U-verse is all very fine and dandy, but the pricing is far worse than cable, and certainly far worse than DTV or DN.Alea jacta est! -
Yep, Direct TV.
I had them for three years the first time.
Went all out and with the savings in my one year off, have all other sets on over the air signals.
We just went back to Direct TV a month ago.
I could go either way, but this way, we get Sunday NFL ticket.
Direct TV gives you more channels, more movies, for not much more money.
Direct TV is a better deal.
I went with Choice Plus with no HD.
Besides, my receiver up-converts all incoming signals anyway.
( but I do notice my over the air is superior in quality )
I also have hooked, the crappy Acer I mentioned in other posts, to my HT, so I have internet music and TV there as well.
Good luck in your quest.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
nooshinjohn wrote: »I wish it were available here, but in Corn Country we are lucky to have a toilet that flushes.
Same thing here John (I mean at home three hours North of Boston, not in Beijing)!
Well said!! What a bunch of idiots!
nooshinjohn wrote: »I have been on hold now with the worst company on the planet, COMCAST for over 30 minutes now:mad::mad:....
We have a Comcast service center right here in New Castle County. I don't think I've had to wait more than a minute for Customer Service unless of course there was a major outage due to a thunder storm.
They got it down very well here, I guess they are going region by region to get it right around the rest of the country. -
I would disconnect cable and listen to great music or read a great book....
except I still need the "fix" of the internet ! -
Had DirectTV for years without a glitch EXCEPT in times of very heavy rain or snow.. moved on to a fantastic wooded lot with huge trees = no line of sight for my DirectTV dish...Comcast was the ONLY choice went thru hell for months (search comcast here ) but after 12 or so trips here , replacing everything, testing, scanning, etc they got it right and not a problem since..a happy Comcast customer now................their CS was always first rate for me at least but the techs in the field weren't the best, especially the contractors they used.................
I fired the cable company a long time ago. Hulu and bittorrent for me. Yeah I said bittorrent and I know you use it too.Onkyo TX-SR805
Polk LSi15 , LSiC, LSiFX
Parasound Halo A52
Panasonic 42'' Plasma
Oppo BDP-83
Sonos
Panamax 4300
Audioquest cables -
I have a family member who works for them...some of the stories are completely insane...in a bad way, so nothing surprises me. And they are going through a re-branding of sorts but only telling their employees it is to compete with AT&T. If a company cannot recognize and admit to problems, then they will never solve the problems.
DirecTV will go above and beyond to keep customers...IMO
