Green Laptop
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited November 2011 in The Clubhouse
I am looking to get a green laptop for my gf. The reason it has to be green is it is her favorite color "long story". Other than low quality dell is there any other company that produces green laptops?
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • Systems
    Systems Posts: 14,873
    edited May 2010
    Have to disagree with the low quality Dell statement. My wife has had two Dell laptops with zero issues with them. An Inspiron 6000 that she gave to her sister and her current Studio 15, which is green by the way:)
    Testing
    Testing
    Testing
  • bigaudiofanatic
    edited May 2010
    After working with them and seeing the problems with them, I will not buy one nor will all 3 of my computer teachers they are all against them as well.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Systems
    edited May 2010
    So what problems are you guys seeing with them? Are they the cheap line or are they high-end models?
    Testing
    Testing
    Testing
  • John30_30
    John30_30 Posts: 1,024
    edited May 2010
    Maybe HP.
  • thsmith
    thsmith Posts: 6,082
    edited May 2010
    I used a Dell at work for 5 years and it held up very well. I now have an HP for work and I have had the fan, motherboard (twice) and docking station replaced in 2 years.
    I have to disgree wrt Dell.
  • shadowofnight
    shadowofnight Posts: 2,735
    edited May 2010
    Look up Alienware.....a bit overpriced, but very cool....she will know you care :)
    The first rule of Fight Club is you don't talk about Fight Club
  • bigaudiofanatic
    edited May 2010
    Now owned by dell sadly.
    We have seen just all around poorly build and made machines. Different things have failed even at a teachers job "detective" they fail a lot.
    If I have to I will go with dell but not without getting my arm twisted first.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Jstas
    Jstas Posts: 14,849
    edited May 2010
    When you want to say it with love, say it with Krylon!
    Expert Moron Extraordinaire
  • bigaudiofanatic
    edited May 2010
    That stuff is amazing I will say that.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • coolsax
    coolsax Posts: 1,826
    edited May 2010
    check out sony.. they have Green laptops in their Vaio E series
    www.sonystyle.com
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Kex
    Kex Posts: 5,219
    edited May 2010
    Buy an Apple, and then grow some Irish moss on it ... the only downside is that you'll have to spray it with moisture every day.
    Alea jacta est!
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2010
    I have a HP and the Dell XPS, I like it. It's very fast and performs well out in the field. I've had it in harsh field enviroments and it has not let me down.
    It's not green but it is a bad machine
    http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=DKCWMN1&s=dhs
  • John30_30
    edited May 2010
    Alienware.... For a while before Dell bought them, they were the same machine that Gateway and eMachines were putting out at a fraction of Alienware's price.
    If you want a hot boutique laptop get a Sager or get a Ferrari (red or black only)
    Or an Asus Lambo- also, comes only in yellow
  • JimKellyfan
    JimKellyfan Posts: 696
    edited May 2010
    coolsax wrote: »
    www.sonystyle.com
    Agreed on the Sony.
    Love the Krylon idea Jstas !
    I would also go with the new processor I3, I5 or I7, depending upon her usage and your wallet.
    I have an old Vaio ( 2005 ) that still outperforms my new Acer ( 2009 ), I will never go AMD again.
    Intel only.
    That said, I don't think Sony has any AMD's that I know of.
    When I need another TV, PC or Laptop, a Sony it will be.
    I used to be a TV repairman, with three shops, and I saw the least amount of TV's in the Sony lineup.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2010
    Really, you're going to blame that poor performance on the AMD chip instead of the fact that it's an Acer????
  • JimKellyfan
    edited May 2010
    Too, it is bottom rung, and I didn't realize at the time that it was a bottom rung as it had an impressive spec sheet. I believe it to be a sum of it's components to not match or perform correctly. So, right you are, better to blame the fact that it is an Acer.
    I still will go back to Sony though next time.
    Really, it was my bad for limiting the spending budget.
    After throwing a blue ray burner, 4 more gb ram, an OS and office in it, I am stuck with using it, and must accept it, sigh.
    Hopefully this helps others.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • coolsax
    edited May 2010
    Agreed.. I think its more the ACER than the AMD, I've been using AMD chips for years and have no complaints.
    Main 2ch -
    TV 3.1 system -
  • AsSiMiLaTeD
    edited May 2010
    Of all companies, given their obsession with 'image', I'm really surprised that Apple doesn't have a green laptop.
  • bigaudiofanatic
    edited May 2010
    I personally love amd and acer been using their MB and processors for a while no problems.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2010
    Oh wow, hahaha.
    op asks for laptop advice
    Dell is suggested
    op shoots down Dell
    others chime in backing up Dell
    op shoots down Dell
    someone mentions Acer
    everyone agrees Acer's complete junk
    op stands behind Acer
    *facepalm*
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Sherardp
    edited May 2010
    audiobliss wrote: »
    Oh wow, hahaha.
    Dell is suggested
    op shoots down Dell
    op shoots down Dell
    *facepalm*
    Awesome!!! Let him spend his money on the Acer, he'll soon regret it in the end.
  • snow
    snow Posts: 4,337
    edited May 2010
    What happened to no brand bashing allowed? It appears to me from multiple threads that you have posted in that you seem to hate Dell the brand and it wouldndt matter if Acer, HP, IBM or whoever had the identical parts in their machines the Dells would suck as far as your concerned.
    All companies have had winners and losers in their lineups but seriously stop and think for a minute about what you are saying, forget what your teachers have told you and think for yourself. If Dell was really that bad how are they still in business years after they started? And why do you see the majority of posters in this thread are saying they love their Dells? If the problems you say that you and your teachers are having were widespread then surely more of us would be agreeing with you and there would be widespread complaints all over the web.
    I am typing this on a Dell that I bought new in 2004 which makes 6 years of absolutley trouble free service. I have never had a single virus or hiccup of any kind it runs as fast or faster than it did in 2004 and shows no sign of stopping any time soon, which truthfully I cant say the same for my Gateway or Compaq computers. Of course maybe I like the majority of posters here have just been lucky but I doubt it.
    REGARDS SNOW
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2010
    Gotta love it when the only requirement is that it be green (of course, I first took this to mean "environmentally responsible" or some crap like that).
    Hey, I'm interested in a black speaker... anyone know where I can get one? ;)
  • mdaudioguy
    edited May 2010
    snow wrote: »
    REGARDS SNOW
    My guess is, take most of the major consumer brands apart and they're essentially the same on the inside. I'm not even sure what makes a Dell a Dell, or an HP an HP, other than the logo on the front.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited May 2010
    mdaudioguy wrote: »
    Why yes I do......
    http://www.greatblackspeakers.com/
  • bigaudiofanatic
    edited May 2010
    audiobliss wrote: »
    Oh wow, hahaha.
    Dell is suggested
    op shoots down Dell
    op shoots down Dell
    *facepalm*
    Correction to myself I use Asus and like asus. Acer laptops are alright. I know form experience that dell is junk EXPERIENCE in the field and from people telling me about them and the problems.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited May 2010
    mdaudioguy wrote: »
    Except apple.:p except their Processors.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • mdaudioguy
    edited May 2010
    Those are FREAKIN' AMAZING!!! :)
  • audiobliss
    edited May 2010
    I laughed out loud!! Totally didn't see that coming. :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
