InFocus X1 DLP Front Projector only $899.00
Ron-P
Ron-P Posts: 8,520
edited May 2003 in Electronics
Can't pass this up so I am ordering one tomorrow if Best Buy does not have any instock. For only $899, plus a 5 year warrently, plus a 30 day trial period, it's a no-brainer. Heck, I can sell my Mits 46" and break even if not be ahead a little.
I've read some reviews and it seems to be a great projector for an excellent price.
InFocus X1
Peace Out~:D
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • wallstreet
    wallstreet Posts: 1,405
    edited May 2003
    Remember, you get what you pay for. And you're only getting 800X600 resolution on this baby. To get a native hi-def signal, you need 1280X720 res. So anytime you run a widescreen movie you'll get bars just like you do on a 4x3 screen. Also, I'm not sure how the project supports HDTV when it doesn't have component inputs. I'd take a serious look at LCD's that support native hi-def before plunking a 1000 for this guy.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2003
    if you do get this buy the screen after you setup the projector. if i go front i will go no less than 125in diagonal it is go big or get out of my ht lol. you might have ti buld a new audio rack
  • mantis
    mantis Posts: 17,201
    edited May 2003
    using a bussiness projector for home theater is ok,it's a good way to get a more movie feel without spending the big bucks.For what they are selling if for,what the hell.My advice is get a good screen now and savefor down the road better projector.
    Ron consider throw distance before you buy.Check it's spec's.
    It's the first dlp bussiness projector I have seen.Stewart canhelp you with the purchase of a film screen.Fixed is the way to go if you don't want to drop over 5 grand into a screen.
    In the rron you have,I'm not seeing a bigger screen then a 84.That even might be to big.
    Dan
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2003
    Ron,
    I think the driftwood deserves better. I saw this same ad for Best Buy and considered it (briefly!) before I compared it to alot of the other entry level units out there. I think you might want to keep looking. The resolution is pretty low for an HT projector. Screendoor effect is said to be quite noticeable also!
  • goingganzo
    edited May 2003
    i think a nighthalk screen wil be about a grand for a fixed screen. if you want a good projector for about 3-4k
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    Guys, this is an entry level FP and as entry level as you can get. Cannot expect much for 1k, then again from all the reading I have done over at AVS and the HTF, 95% of the reviews are steller.
    All I can do is a 6' screen, the projector seems to work best at 1.5 from that. Which should work out nicely for set-up.
    It's so inexpensive, the reviews are above average and it comes with a 30 day risk free trial period, you cannot go wrong. I gotta give it a shot. It will be a direct trade for my Mits so I will be out no coin. If it runs for a couple years, great, I''ll upgrade to a new model at that time and that's if it looks good and is worth keeping. But, I'll never know if I don't give it a shot.
    Peace Out~:D
    If...
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    Just finished up with InFocus and the projector is shipping today, $1,076.42. Plus, I'll get $100 off via a mail in rebate, only $976.42. I have to give this thing a shot. 30 days to try it out and I'm out a few bucks to send it back if I do not like it.
    Plus, when I regiseter online, they'll extend the warrently to 5 years parts and labor, free.
    It's got some draw-backs, but it seems they can be overcome with tweaking and the proper light grey screen color. I'm willing to sacrifice some PQ going larger with an inexpensive front projector, how much, I'll let you know next week when it's up and running.
    Here are some specs off their site...
    InFocus InFocus X1 Projector General
    Aspect Ratio: 4:3 standard; 16:9 wide
    Brightness: 1100 max ANSI lumens
    Contrast Ratio: 2000:1 full on/full off
    Data Compatibility: SVGA, VGA, XGA, Macintosh®
    Display: DLP™ by Texas Instruments: 0.55" SVGA DDR DMD
    Image Size (diagonal): 2.7’ to greater than 21.6’ (0.8m to greater than 6.5m)
    Light Source: 150W SHP/ 3000 hours
    Native Resolution: SVGA (800 x 600)
    Projection Lens: Zoom lens with manual focus and manual zoom adjust
    Projection Methods: Front, rear, ceiling
    Video Compatibility: NTSC, PAL, SECAM, EDTV, HDTV (1080i and 720p RBGHV)
    Maximum Projection Distance : 32.3’/ 9.8m
    Minimum Projection Distance: 5’/ 1.5m
    Zoom Ratio: 1.2:1
    Size
    Dimensions: 9.8" (W) x 12.5" (L) x 4.2" (H)/24.9cm x 31.8cm x 10.6cm
    Weight: 6.8 lbs/ 3.1kg
    Input
    Input Sources: Computer (VGA 15-pin HDDSUB female); video (S-Video 6-pin mini DIN, component
    RCA through S-Video adapter, and composite video RCA); audio (3.5mm mini-jack)
    Output
    Audio: 2.5-Watt mono speaker
    Brightness: 1000 max ANSI lumens
    Number of Colors: 16.7 million
    Other
    H-Sync Range: 31.5 – 80 kHz
    Lamp Warranty: 90 days or 500 hours, whichever comes first
    Operating Temperature: 5° to 40° C at sea level (0 to 10,000'); 41° – 104° F
    Power Consumption: 200-Watt (typical); 250-Watt (maximum)
    Power Supply: 100V-240V at 50-60Hz
    Ships Standard with: Soft carry case, Lens cap, Wireless Conductor™ Remote Control (including batteries), color-coded cable straps, standard VESA 15-pin analog computer cable, 3.5mm computer audio cable, Component video input adapter cable, power cord (national and regional variants), SCART adapter (EMEA Only), Projector System CD includes: multi-language projector User Guide, projector Quick Start Card, URL/service information/accessories after market, user manual (printed version, Quick Start Card (printed version)
    V-Sync Range: 50 – 85 Hz (85Hz at XGA only)
    Warranty: Two-year standard warranty on parts and labor
    Some things are too good to be true, this could be one of them. We shall see.
    I already have a buyer for my Mits if I decide to sell.
    Peace Out~:D
    If...
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    It accepts 480p or 1080i via the VGA input, all I need to do is buy the breakout cable (about $50).
    Peace Out~:D
    If...
