pre prow interconects
goingganzo
goingganzo Posts: 2,793
i have ben reaserching cabbles i think i am going to get monster m850i should i wait and get beter ones? i have never spent this much on cabbles. i was recomed the 550i. i havent reasheched cabbles and would be greatley apreasheated.
    F1nut Posts: 51,763
    edited May 2003
    I highly recommend MIT cables, http://www.mitcables.com/ The Shotgun series are very nice, but alot more money than the m850i's. Shop around on Audiogon and at http://ecom3.aspre.net/cgi-bin/TheCableCompany.storefront/
    for used cables as a way to get better stuff for less money. You will hear a MAJOR difference between $80.00 cables and $500.00 cables more than the difference (if any) between $20.00 cables and $80.00 ones.
  • mantis
    mantis Posts: 17,378
    edited May 2003
    goingganzo
    you got mail.
    Dan
  • goingganzo
    edited May 2003
    your email is not working manits i tryed twice.
  • goingganzo
    edited May 2003
    i was serching audiogon and found some people selling cabbles and they have a 30day money back garentee.
    http://signalcable.com
    he has a 50 buck cable and a 35 cable
    thanks for the help.
  • polkatese
    polkatese Posts: 6,767
    edited May 2003
    Gonzo,
    there are enough crowd in this forum that can give you reviews on signal cable cables (Russman, TroyD, TonyPTX, Gshisme, myself, and some others that I am sure will surface if you asked the question). Personally, I used Analog Two and been very satisifed with them. Let Frank know that you are part of the club Polk and he might give you a little bit of discount and/or free shipping..
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mantis
    edited May 2003
    goingganzo
    dmantis20@aol.com
    try that
    Dan
    F1nut Posts: 51,763
    edited May 2003
    Ganzo, case in point........
    Originally posted by dorokusai
    Conclusion: I was a believer in cable benefits, but have never had another reference point to set a standard. MC was my standard. Herein lies the main difference in comparing these two cables, cost. MC = $45(New), MIT($300). The resulting soundstage was SO much improved and enjoyable that the benefits far outweigh the cost of these cables. I would recommend them, or at least suggest that they be a demo choice at the very least. Personally, I am looking for used ones right now. Thanks for reading.
  • goingganzo
    edited May 2003
    so do you think i should go with the sigonal cabbles with the bullet plugs? or the monster m850i ? they will both cost about the same.
  • polkatese
    edited May 2003
    Gonzo,
    got to at least try analog two with bullet plug, I can tell the difference on my system, I use 'em for my two channels. Can't really tell you which one is better (m850i and analog two). I did a brief shoot out between m550i and Analog two (which I am still using them both for SACD/DVD-A switcher) and the difference is the much more details and more defined bass. You can chat with Frank and let him give you his perspectives, I know he shootout his cable extensively with monster M series...
  • gidrah
    gidrah Posts: 3,049
    edited May 2003
    I might be able to loan you a pair of Analog 2s.
    Make it Funky! :)
  • goingganzo
    edited May 2003
    i just sent him a email for a price for 7 cables with the bullets. it will cost me about the same for the 850i vs the sigonal cabbles
    i will use the 30day garentee but i bet i wint use it. also i dont have my amp yet. i am waiting for it to be ordered
