Sealed cabinets?
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    zingo wrote: »
    A shallow staple?
    I don't have any staple-guns or staplers that can fit inside M5's. Well, I do, but I don't think a tiny paper stapler will have the strength to bury a staple even a millimeter into the cabinet.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • gdb
    gdb Posts: 6,012
    edited May 2010
    suspend from small screweyes and string/fishing line for a true suspension loudspeaker !:D
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    gdb wrote: »
    I might have cable management stuff from my computer, including stick-on mount points. I suppose I could run some string to create a basic net to keep the filling up? Otherwise, would double-sided tape or something like gorilla glue work?
    F1nut Posts: 51,777
    edited May 2010
    Double-sided tape is ok, do NOT use Gorilla glue....for anything. In fact, if you have some around, throw it out.
    I believe you're over thinking this. Simply fluff up the poly fill and shove it back up where it belongs.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    +1
    Don't worry about it. Put it back in place, and check it again in 5 years to make sure it hasn't fallen back down again.;)
    +1 on the Gorilla Glue comments as well. I hate that stuff.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    Alright. I finished up. I did fluff it up a bit (refolded it) and shoved it back behind the tweeter. I ended up mortiting both pairs of tweeters, woofers, and radiators. I tried to mortite the crossover but that was a pretty bad idea; I cracked the plastic edges but it's still sealed. I should have left that bit alone--and I did on the second cabinet. I actually had to repack a choke and luckily caught one point where two board components were touching too closely. I'm a touch worried about those M5-II's as it looks like I have a bulging (around the waist) ?resistor?capacitor?. They sound alright, but actually pretty crappy besides my SDA-1's.
    Does anyone have (a link to) the schematic for the original Monitor stands or other good variants?
    I'll be building a wood stand to bring them up ~2' and keeping them flat. As they are now, they're flat on the ground. I found they sound fine at desk/cabinet height, but they sound like crap on the floor. I will probably go overboard and build two stands each; one floorstanding and one for use with a desk.
    In other news, I heard about a pair of 10A's in my area for $50, but the seller hasn't gotten back to me after I inquired about some other parts.
  • zingo
    zingo Posts: 11,258
    edited May 2010
    What don't you guys like about gorilla glue?
  • gdb
    gdb Posts: 6,012
    edited May 2010
    They probably don't/didn't know how to use it and got some on their fingers, a very lasting mistake.:)
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    Right.
    Anyways, does anyone have the Monitor 5 stand specs? The speakers sound really crappy sitting flat on the floor. I tried searching the forum but I couldn't find much (I didn't look past a page or two) quickly. I've got plenty of scrap wood etc. downstairs, so it'd be pretty easy to put together a stand.
    F1nut Posts: 51,777
    edited May 2010
    A few of the reason I prefer yellow glue over Gorilla glue.
    Yellow woodworker's glue (Polyvinyl Acetate) is an excellent choice for bonding wood as it penetrates well into the wood fibers to create a bond. Gorilla glue (Polyurethane) does not penetrate into the wood fibers.
    Cured yellow glue works better with the natural expansion and contraction of wood. Cured Gorilla glue is rock hard, yet fairly brittle, so it doesn't do well with the natural expansion and contraction of wood.
    Yellow glue cures by evaporation and any excess is easily wiped off before it cures. Gorilla glue cures by a chemical reaction with moisture and the foamy excess should be left to cure before chiseling, sanding or planing it off. Can you say PITA extra work!?! Since Gorilla glue needs moisture to cure, you have to wet at least one surface. The problem there is that wood lumber doesn't like water all that much.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited May 2010
    I agree, gorilla is better suited for plastics and hard non porous surfaces,.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    So I wouldn't be taking a leap of faith in stating, "you do know how to use it!":D
