Open Office
daboyz
Just bought a new laptop that didn't come with Microsoft Office and was told about a free download called Open Office which basically has all the bells and whistles you would need.
Anyone ever use it? Pros or cons?
Post edited by daboyz on
it is good stuff, download it and give it a try, don't cost nuttinDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
+1...I like it.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Yeah, I'm a big fan. You do run into compatibility issues once in a while with MS Office users, so beware if sharing documents.If you will it, dude, it is no dream.
its good. i like MS office more, but that's just because i've used it for so long.
Open Office works just fine though, most of the commands are similar, if not the same, MS Office.
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
If you're not using at work or just creating your own docs, it's great.
Priced right, too!"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
I have used open office for years. It works great for most everything that i need. There are a few compatibility issues with office 2007. Overall it is a great product, check it out, it is free.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I use it and it is great when you are using it with OpenOffice users. However, the ability to read/write Microsoft Office 2007 documents without getting the formatting messed up is still not there.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
http://en.wikipedia.org/wiki/Microsoft_Works
If you do decide to use Open Office nonetheless, sending documents using the integrated PDF feature is an easy way to make sure the recipient will see what you think they will see.Alea jacta est! -
Microsoft Works sucks. If you got it for free, you got ripped off.
OpenOffice...I love it!Expert Moron Extraordinaire
Open Office is fantastic, imo. I've used it for several years now, and never run into any of the compatibility issues that I've heard of from other users. I can also honestly say that I find it easier to use than the newer versions of MS Offices
I have been using OO for several years as well with no compatibility issues at all. You have the option to save an OO document/spreadsheet with Word or Excel file extensions too. A few things work differently in OO but I find it very easy to navigate.--Gary--
I would love to be able to use openoffice. I like the look and functionality of the actual programs. I think they also leave a smaller footprint that MS Office. The only problem for me is that I use a lot of programs that link their databases or export their data to Word and Excel, and it my testing those links are specific. I must have Word or Excel to use the linking feature.
OpenOffice is a fine office suite, but I don't have problems with MS Office either. Both have morphed into absolute behemoths, and neither have what I would consider a small footprint for systems with modest specifications (especially older laptops, or even bargain basement new laptops).
If advanced formatting features are used in OpenOffice, there is a significant chance that some of that formatting will get lost in the conversion to MS Office format, especially in complex documents, or presentations. This was especially true of presentations when I last tried it. The included "save to PDF" feature mostly solves this issue for standard documents, but even that is not quite as precise as an Adobe PDF (some spacing can get modified slightly, but there shouldn't be any major issues IME).
MS Works is not nearly as advanced as either, but it does offer a workiing alternative that is far more sophisticated than WordPad.Alea jacta est! -
I use open office when i can -- it works fine in standalone mode. If you do word processing, spreadsheets and presentations in a business / corporate environment then you're probably stuck using MS office, for the sake of 100% compatibility. That said i got a corporate discount on Office 2007 a couple of years ago and and -- I'd take MS Office 2003 over MS Office 2007 any day. The idiots in redmond changed about 85% of the user interface in Office 2007 - rendering unusable for dinasours like me.
just my 5 cents worth
--wayne--Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
wayne3burk wrote: »... I'd take MS Office 2003 over MS Office 2007 any day. The idiots in redmond changed about 85% of the user interface in Office 2007 - rendering unusable for dinasours like me. ...Alea jacta est!
Open Office is okay, just remember you get what you pay for....
I use Microsoft Home and Student, very reasonable option as you can put it on three computers....Testing
Testing
Testing
