Pioneer SC-05/07 Firmware
Sherardp
Sherardp Posts: 8,038
edited April 2012 in Electronics
Gents,
Just wanted to inform you that Pioneer has released a firmware fix that takes care of audio dropouts that occur with the DD+ codec. In order to get this fix call your local service center for the patch. I have Pioneer coming out to my place tomorrow to install it on mine. Also when speaking with the Pio rep, you cannot perform the firmware fix yourself, you have to call the local service center, ymmv. Mantis I'm sure you maybe able to work this out since your a dealer. Just an update as I have complained to Pioneer for sometime about this.
Post edited by Sherardp on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2010
    How much does it cost having a tech come out?
  • drselect
    drselect Posts: 664
    edited April 2010
    Sheradp, do you happen to know if it also for the SC-25/27?
  • Sherardp
    edited April 2010
    drselect wrote: »
    There was a recent firmware update for the SC-25/27 that also fixed this issue. It actually prompted me to express my concern to Pioneer in regards to the prior models which most of us own. As for cost it is not costing me anything here, since I had Pioneer USA to contact a local office here to perform the task locally. YMMV. Give them a call and see what they say.
  • mantis
    mantis Posts: 17,444
    edited April 2010
    I did not hear of this firmware but I will now look into it.
    Thanks for the heads up
    Dan
    Dan
  • Retro152
    Retro152 Posts: 985
    edited April 2010
    Great info Sherard. Much thanks.
    Pat.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • Sherardp
    edited June 2010
    Confirmed, no more audio dropouts when playing back DD+ codec via HDMI. This firmware update is good through all models to include, SC 25/27 and 05/07. Check with your local dealers. It was actually a very simple fix, new firmware for DSP chips are 1003. You can check yours by turning vol level to --- on the front panel turn multizone to off. Then power up pressing power + return on the front panel for 5 seconds. I will get with Pio rep tomorrow for the files. Update took less than two minutes and simply required using thumbdrive. If you guys are interested let me know.
  • Grimster74
    Grimster74 Posts: 2,577
    edited June 2010
    Already told a brother I wanted the info but I'm sure you'll hook a brother up.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited June 2010
    If it's that easy, I'm definitely interested.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    I think I'll have to do the same....if its that easy no problem!
  • quadzilla
    quadzilla Posts: 1,543
    edited June 2010
    Same same. I think I could manage to do that without **** it up.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • pavment
    pavment Posts: 9
    edited June 2010
    This fw should also fix the remote power on issue where the unit will not respond to power button from the remote. But do not perform the upgrade by yourself, it will void the warranty.
  • Disc Jockey
    edited June 2010
    Sherardp wrote: »
    Any updates on this Shererdp, did you get the files?
  • Sherardp
    edited June 2010
    I have not as of yet ,but should be able to finally get them when I get back in Japan.
  • Disc Jockey
    edited June 2010
    Okay, thanks.
  • mike929
    mike929 Posts: 4
    edited October 2010
    How much is this update?
    FYI - have a SC-25
  • doggie750
    doggie750 Posts: 1,160
    edited October 2010
    interested.....I am on the boat as well........
    STATUS?
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • mole'
    mole' Posts: 3,160
    edited October 2010
    did not see how much the update cost
    Thx for the info
    mole'
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2010
    I don't think they charge for the update, but you have to take it in to get the update, last I knew.
    You would think they would have a method for doing it yourself, other manufacturers have for years. Save them a fortune in support, and save the end user the trouble of having to unhook everything.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited October 2010
    Are these the updates and instructions at this link? http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/EliteReceivers/ci.SC-27.Kuro?tab=F
    The site indicates the last update was 10/13/2010.
  • Sherardp
    edited October 2010
    There is no charge for the update. You have to take the unit in for the flash update. This will flash the chipsets in your AVR and bring it up to speed. The DD+ will flash the DSP chips and prevent the audio dropouts with the Dolby Digital Plus codec.
  • doggie750
    edited October 2010
    Sherardp wrote: »
    @ Sherardp, the update must be done by the service rep and there's no way that the owner can, right? It's just a P A I N in da A$$ to disconnect...:mad:
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • Sherardp
    edited October 2010
    Yes Doggie this is correct. I had the Pio rep come out to my house and do it onsite. I have way to much stuff connected, and I agree a pain in the a$$ bro.
  • doggie750
    edited November 2010
    Sherardp wrote: »
    MAN MAN.:biggrin:....you are a VIP.....so did you have to pay for such service or someone you know?
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • doggie750
    edited March 2011
    FINALLY, I have the beast unplugged last night with care. I felt like a surgeon :smile:. Called the local Pioneer branch for service, I couldn't believe the bonding between a Man and a unit like this can be so intimate. :wink:
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • dmsaudio
    dmsaudio Posts: 1
    edited April 2011
    Doggie,
    Did u do this yourself? Stunning that we are asked to take this monster into a shop.
    Would love a copy of the FW is somehow someone has it. Thanks.
    Dave
  • Sherardp
    edited April 2011
    Contact your local Pio rep and see if they will pass it to you with the instructions. It was super easy for me to do. Be very careful though, some guys over and AVS bricked their units trying it themselves.
  • Suddeth
    Suddeth Posts: 1
    edited April 2012
    Good to know that you guys have done it yourself. I am also going to try it out. I guess first I have to contact my Rep to see if I can get instructions from them. Hats off to all of you guys:cool:
