Lsi7 scratch
rooftop59
rooftop59 Posts: 8,121
edited May 2010 in Troubleshooting
Hey Guys,
I bought a used pair of Lsi7s that sound amazing but have some pretty bad scratches on one of the side panels. If I was going to use stain to repair it, what brand/color of stain would you recommend? Obviously I could just restain all the panels, but I would like to avoid all that extra work if possible;)
Thanks,
Paul
Game Room 5.1.4:
Bedroom 2.1
Post edited by rooftop59 on
  • BeefJerky
    BeefJerky Posts: 1,320
    edited April 2010
    You might consider something like this:
    http://www.amazon.com/dp/B000GOUE74/?tag=aom-ch1-20
    I know it seems cheesy, but they work quite well. I've used them on bookshelves, and while they won't completely get rid of scratches, it will make them much less noticeable.
    edited April 2010
    There are some other products that can be rubbed in to mask scratches in wood grains. Remember the secret is that wood has grain...grain is darker than wood...and even what B-jerky has recommended may work because of that. If the color is close enough it will blend it to match the rest of the wood. If it is darker the stain or marker will look like 'grain'. Depends on just how BADLY scratched you unit is...because if it's really marked up you'll have to refinish.
    cnh
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited May 2010
    Sharpie has a marker out for anything I guess. That is really nifty though...
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • rooftop59
    edited May 2010
    Thanks for the help guys. The marker idea got me looking around and I ending up picking this up at the office depot right around the corner. They worked *okay*, but I will probably end up just refinishing the wood panels eventually.
    http://www.amazon.com/ReStor-Furniture-Touch-Up-Markers-MAS18000/dp/B0013CGBQQ/ref=sr_1_2?ie=UTF8&s=hpc&qid=1272897597&sr=8-2
    Peace,
    Paul
    Game Room 5.1.4:
    Bedroom 2.1
  • sandworms
    sandworms Posts: 1,043
    edited May 2010
    Aren't the side panels plastic ( veneer ) on the lsi's?
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Jer.War
    Jer.War Posts: 180
    edited May 2010
    Real wood veneer on the LSIs...Refinishing is an option, but the veneer is thin, so deep scratches could be tricky
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
