3.1 for home theater?
eloplayspolo
eloplayspolo Posts: 1,117
edited December 2008 in Speakers
How would a 3.1 setup sound for a home theather in a small room... the tv will be viewed from about 7 feet away.
I was thinking a step above entry level polk floor speakers, a sub, and a center chan.
i know i would lose the whole surround sound... but im thinking this may be a better investment for a small room... correct me if im wrong.
if im not what polk towers would u recommend.... ive seen a lot of good deals on the monitors
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • Upstatemax
    Upstatemax Posts: 2,625
    I did that till I got in my new FXi3 surrounds...
    Monitor 70's for the fronts, CS2 Center with a PSW10 sub. I think it sounded fine... The surrounds help, but you can get by on a 3.1 set-up.
  • Early B.
    Early B. Posts: 7,900
    This may sound strange coming from me right now, but consider setting up a 2.1 channel system and place more money into your fronts instead of buying a center channel at this time. If you're gonna stick with Polk, go straight to the premium line and grab a pair of Lsi9's or 15's, especially if you'll be listening to music. You can probably find a great deal.
    "God grooves with tubes."
  • Conradicles
    Conradicles Posts: 6,045
    Also, you can use SDA's as your fronts and you will not even need a sub if you set your receiver EQ correctly. You may not even need a center as the SDA's image like crazy in the sweet spot!
  • Chitown_Badger
    Chitown_Badger Posts: 66
    Early B. wrote: »
    Assuming he has the amp or receiver to drive them. If not, this could get expensive in a hurry.
    For floorstanding...monitor line and last years RTi line can be had at a deal right now.
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
    AVR: Pioneer VSX-1018AH
  • PolkThug
    PolkThug Posts: 7,532
    In a small area, ditch the center and go 4.1
  • Face
    Face Posts: 14,340
    PolkThug wrote: »
    I agree, rears are more valuable for surround sound than a center.
  • Kex
    Kex Posts: 4,943
    Early B. wrote: »
    That's probably what I would do, if 4 ohm capability is not an issue. The "phantom" center effect works very well if the seating is well positioned IMO. With the right equipment, even 2.0 can be a thrilling experience, but I like the idea of LSi for musical capability as well.
    Otherwise, I like the 4.1 solution, with any of the RT(i) series speakers.
    Done properly, I don't think 2.1 with LSi, or 4.1 with something else, is really much of a sacrifice.
    Alea jacta est!
  • eloplayspolo
    okay so 2.1... like im running now with crap yamaha bookshelfs and a terrible sony sub and a terrible receiver..... only with a good receiver and speakers and subs.
    if im going to be watching from a bed, laying down with my girlfriend laying on my chest ( :) ), would i be better off with some surrounds mounted up high angled down at me?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    are the Polk Audio R50 worth 58 dollars each?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    bump
    i need to know asap its not gonna be on sale and i can still call them and get it on sale tomarow
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    ii can get them for 48 dollars eaech!!!!!! should i buy 4? for my rears also?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • RutgersFTW
    RutgersFTW Posts: 458
    I'd skip the rears, man. 2.0 or 2.1.
    At that price you can certainly check them out and see if you like them. They should be an improvement over what you have. Also consider grabbing a pair of Monitor or RTi series Polks from the eBay store for a little more. They should be a big improvement.
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • Kchill
    Kchill Posts: 260
    200 bucks, get a center for about 70 bucks...can't go wrong there.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • ben62670
    ben62670 Posts: 15,969
    Ben
  • sucks2beme
    sucks2beme Posts: 5,558
    I run 3.1. The center really has to be there for the dialog
    The Mrs. refuses to allow the surround speakers. I had RTI4 and RTI 6
    speakers to go with the RTI 10's, but I ended up selling them, and I don't
    really miss not having them. Strangely enough, the SVS she didn't seem to mind. :confused:
    I rarely watch movies, and go upstairs to the 2-channel for music.
    Build the best 3.1 for now, then decide to add on later.
