Testing drivers... an ebay Seller Q&A
Tour2ma
Looking at a couple separate drivers on ebay. Here's Q&A with Seller:
Is this a legitimate, if not exhaustive, test?
from Tour2ma
Could you please confirm the condition of the voice coil and cone assembly. Have you applied a music signal to each one to verify that all is working as it should?
Seems reasonable for checking that the cone travels freely in both directions (if check with both polarities), but not a test I would have thought of.from Seller
tested with a c battery. responded as it should as far as i can tell.
More later,
Tour...
Vox Copuli
Tour...
Vox Copuli
Post edited by Tour2ma on
it must be legit - russ tells alot of peeps to do itDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
It tells you if it is COMPLETELY blown or not, but I wonder if it would tell if it was partialy damaged?
Russ has said to use the battery to check polarity onlyDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
