SDA Interconnect
abmarsh
abmarsh Posts: 109
edited January 2003 in Troubleshooting
Does Polk sell SDA interconnect cables to replace lost or damaged items? It's not in their parts list.
Post edited by abmarsh on
    F1nut Posts: 49,804
    edited January 2003
    It's listed as a SDA cord, but last I heard they only had the twin blade type. If you need a pin/blade type then you'll have to make one or Har has one for sale that he made, looks nice.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=7260
  • flason
    flason Posts: 278
    edited January 2003
    From what I understand, the blade part is there to hold the pin in place. Prior to finding one from this website, I used speaker wire which was recommended from Polk tech support. It will produce the same effect and is easy to make. Rat Shak has a pin that you can crimp on the wire and fit into the hole.
