need help with box ideas for a crown vic
98thumpin
i am buying vince's subs from him and i have a crown vic, i was wanting to mount the subs inverted, will this method sound the same? also ill be building a box and i never built one before, ill be posting a pic of my trunk so ideas or plans will be greatly appreciated. i need a blueprint for a box. that will fit in my trunk. if i have to ill mount them iso barriec. i was thinking of building an amp rack into the box, and adding neon later down the road. i know nothing about fiberglassing, so wood is what ill be building it out of.
John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Post edited by 98thumpin on
yes, inverted subs sound the same; coming up with box blueprints is pretty much my department here on the car side - to do this i need accurate measurements of your trunk, and a link to the t/s specs of the subwoofers (or you can just give me a volume, but i won't be able to say anything about the performance of the resulting box). i also have to know how much woodworking skill you have - i.e. are 30 degree angles okay, or do i have to stick with 45 degree, or if you're really not that good, i have to stick with 90 degrees... that sort of thing...
oh, and i have a bitchload of work from now till next thursday at the earliest, so it'd have to wait until at least next fridayIt's not good, very fundamentally simply not good. - geolemon
well to answer a couple of your questions, i have a circular saw and i know how to set the angles i always measure twice cut once. 30 is fine or 45, i know 90 is easy but it reasults in a bigger box. do you want a total trunk measure ment or useable (where the box will be located)? i will post a link with the specs, and ill tell you what the measurements are sometime soon, no rush though, i dont have to build right away.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
the length 41 inches, the width is 26 inches and the depth is 15 inches, there is a pic of my trunk in the garage sale forum, under it must go.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
the subs are two 12 inch flame q 450w, and two 10 inch flameq 450w audiobahn.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
u gonna help meJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
you'll notice of course that i said at the earliest this past friday... i was out of town all yesterday, and have homework to do right now... when i get the time, yes, i will help you.It's not good, very fundamentally simply not good. - geolemon
ok im sorry time escaped meJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
