Is there a way to build-in LSiM over a fireplace?
    Viking64 Posts: 6,707
    Get a Monoprice amp and you won't need a fireplace.
  • BlueFox
    BlueFox Posts: 15,251
    Best suggestion yet. :)
  • T-R
    T-R Posts: 5
    Here's the room as it is today: https://photos.app.goo.gl/3XfFsU7Xipghzt5s5
    Will do full renovation some time next spring/summer and this is when I want to re-finish the brick wall with something else and build some kind of space on the side for the firewood. This is just preliminary _ideas_ on placement, not design itself: https://www.homedit.com/cool-firewood-storage-design
    As you can see, I don't have much options. TV in this deep corner looks stupid and out of place. I don't know how much I can change the existing fireplace... maybe possible to lower the deck, we'll see.
    gudnoyez Posts: 8,078
    edited October 2018
    Ouch I'm already getting neck cramps from looking at the pictures of where you want to mount it dont do it.
  • T-R
    T-R Posts: 5
    edited October 2018
    gudnoyez wrote: »
    I took some rough measurements and I don't think it's an issue:
    • Distance between seating position (head) and fireplace wall = 489cm (16ft)
    • Distance between eye level and what would be TV center = 103cm
    • This calculates to about 12 degree angle
    Assuming:
    • 1 foot margin for mantel above the fireplace
    • Like 3 inches for mantel itself
    • Center speaker angled down actually above the TV
    Tried sitting down and looking at TV area (center would be about where the shelf is right now) and in the sitting position it's actually quiet comfortable. I mean, I don't sit straight up... I sit in a comfy couch with my head resting in position actually pointing up about the same angle.
    So would it be ok to have LSiM over the TV? Anyone has ever done this before?
  • ken brydson
    ken brydson Posts: 8,659
    This was in a house I showed the other day. I got a neck ache just looking it it...
  • rooftop59
    rooftop59 Posts: 7,990
    In that house it doesn’t make any sense: just remove the sconce and mount the tv on that wall. Or am I missing something?
    Game Room 5.1.4:
    Bedroom 2.1
  • ken brydson
    rooftop59 wrote: »
    Agreed. At the very least angle the TV down a bit...
  • rooftop59
    looks like a nice house though. Did ya sell it?
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,456
    ouch, I got a crick in my neck just looking at that.
  • OleBoot
    OleBoot Posts: 2,157
    I wanted to get my speakers in our family room on the long wall, but that's the one with the fireplace on it. My solution was to put the TV on a low shelf on the hearth in front of the fireplace, as we haven't used it for 20 years. She Who Must Be Obeyed said no. The speakers and TV are still on the short wall. Story of my life.
  • T-R
    T-R Posts: 5
    Yea that is actually the ideal layout - fireplace in the corner and TV in the center. No idea why they forced TV over the fireplace.
