Internal padding or foam rot
jumat148
Recently, I noticed black sticky filings around the feet of my RT 12 speakers.
Upon inspection and after inserting my fingers into the 'Power" ports, I could feel huge chunks of the padding or foam that have dropped down to the ports.
Could someone enlighten me on this and how to remedy the situation.
Appreciate your prompt reply.
Thanks and regards.
Thanks and regards.
Smilies are on
Alright, who's been poking this guys power ports?!?Political Correctness'.........defined
President of Club Polk -
Problem is, those speaks never had foam surrounds, which sounds like what is going down here.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Hi,
Any answers to this question? My RT's have the same issue now (15 years later!), and I notice some distortion. Is there a downward firing passive radiator with foam surrounds, or is this just internal baffle material?
Hmmm ...I don't FEEL tardy! -
Rick_Rated wrote: »Hi,
Hmmm ...
It is internal baffle material. My son had some RT12's gave to him and we found it inside when we rotated the woofer to combat a rattle also well known problem. Might try eggcrate foam material or rolled dacron. Not the loose dacron. -
Signature grade post, right there, folks!
I tip my hat to you, sir.
He's only been waiting 15 years for that compliment. =PJust a dude doing dude-ly things
