RD-0194 rattles
    xschop Posts: 4,728
    I had some spare tinker time and applied the thick butyl mat to the backside of the RD0194's. By ear only, It has indeed cleared up most of the resonating in certain frequencies....
    Tony M Posts: 11,022
    Good idea! B)
  • adam2434
    adam2434 Posts: 995
    One of the 194's in my garage 7C's develops some fuzzy distortion when the temp gets below around 45F. Strange, but true. The distortion was present in the spring, went away with warmer temps, and is now back, now that temps have gone below 45F.
    I installed the 194's several year ago, so not sure if the the distortion is related to the resonance issue discussed in this thread, perhaps brought-on by the lower air temp.
    Regardless, I'm considering buying a new 194 from Polk CS.
    Should I assume that the washer mod is still necessary for the current 194's?
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
    Are the screws still tight?
  • adam2434
    adam2434 Posts: 995
    I will check, but I expect them to be. I checked that in the spring when the distortion was present, and also checked tightness a couple times over the summer.
    Seems like maybe a voice coil issue that develops at cooler temps, but only on one tweeter. The other one is fine at cooler temps.
    OK.
    I've read a few others have had that issue with the newer ones.
    @Darknight did a STUDY on the differences of all tweeters for this Forum.
    Old and new versions were measured every which way and it was very comprehensive and thorough. Check it out using the search box.
    Also, some resolved the noise issue with their noisy "new" tweeters.
    Good luck.
    heiney9 Posts: 25,092
    I have been having an issue with one of my RD0-194's in my SDA 1C's. At a certain frequency I get distortion, a sort of cracking static. It happens during specific piano notes and sometimes on female vocals at a certain frequency. Otherwise is plays fine. I don't think it's blown because it does it a very specific frequency.
    I heard it again listening to Regina Spektor yesterday, when she hits a certain piano note. I thought perhaps it was on the recording, but I've heard it with other recordings.
    Maybe dynamatting the rear will help? These are old RD0's, probably 10 years or more. These were modded about 10-12 years ago with new caps and RD0's by the previous owner.
  • leftwinger57
    Before this became an obvious issue I also had some noise from my brand new RDO-194s. I can't remember if they wanted the noisy ones back but Polk did in fact send me a new set of 194s. I will try to show a bill for 2 new 194s which is at least 1 year after I got the originals. Not knowing of the possible bezel problem they said it Might be a x-over problem which I doubted because they were upgraded. Seems like a very easy fix #10 stainless washers, a bit of silicone ,gasket dry then apply.
    Nothing more nerve racking than hearing that irritating DISTORTION sound.
    I'm very allergic to distortion.
    This is me when I hear it;
    pitdogg2 Posts: 24,634
    A little super glue works, do not know that I'd use silicone. As long as it is dried outside of the box maybe no problems. I think @verb used super glue to hole them in place to mount.
  • leftwinger57
    Ivan, I was thinking about how all here is anti silicone because it gives off gases. In those tiny amounts that high up I can't see to much of a problem but I do have super glue so I will use it so I don't go against the grain.
  • codycatalist
    I got a batch of RD0s that had the buzzing on piano freqencies as well. Polk sent me new ones and they did the same but I REALLY didn't want to bother them for another replacement set. I had one that buzzed less so I used that with a newly ordered Rd0. Yeah it seems the one that buzzed less is hotter than the new one and it causes imaging issues. Just went back to the 2000s for now until I have more money for another tweeter.
    edited November 2018
    it's just messy Lew and super dries super fast.
  • VSAT88
    VSAT88 Posts: 1,227
    I still have one that buzzes / resonates. As I have spoken with Polk and they sent two new ones and one of them still does it I decided the same. I will just wait and buy RD 0198's and see what happens then. I think that will cure it up.
  • codycatalist
    VSAT88 wrote: »
    Yeah I haven't heard of any issues with the 198s.
  • LoStrings
    I had a bad experience with the 194's...I purchased 8 of them for my SRS SDA's, and had problems with fitment, and buzzing. I ended up going back to the 2000's.
  • verb
    verb Posts: 10,176
    adam2434 wrote: »
    Yep. I just got a set of 10 recently. Washers definitely needed!
    audioluvr Posts: 5,457
    I used shoe goo to secure my washers and window seal from Home Depot to dampen the bezels on mine when I restored my 1C's . They sound awesome at high SPL's. See pg 2 of my discussion
    http://forum.polkaudio.com/discussion/179695/new-1c-purchase-questions/p2
  • adam2434
    adam2434 Posts: 995
    verb wrote: »
    Thanks, good to know.
    Ordered a 194 from Kim in CS yesterday.
    Also enjoyed a little tech talk and Polk history with Kim.
  • VSAT88
    VSAT88 Posts: 1,227
    Wonder if someone could upload some pictures of the 0198 so we could scope out the difference between those and the 0194...
    F1nut Posts: 49,857
    They look identical other than the faston tabs.
    F1nut Posts: 49,857
    Other than the RD0198 photo has better lighting, identical.
  • codycatalist
    Don't 198s have two different size terminal connections on the back? My 3000s did at least.
    same with the Rd-0198
    Jesse also stated the same
  • CH46E
    CH46E Posts: 3,579
    Can anyone tell me if the 194s will be phase correct for the RTA12B that originally had the Peerless 5514s in them? I've been wanting to try some 194s in them and now I have a pair on the way.
  • codycatalist
    I think they have different crossover designs with the two tweeters...
    CH46E wrote: »
    Check the schematic against yours and the 12B SL2000 you will have your answer.
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18712.pdf
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18713.pdf
    Looks like the only difference was the polyswitch and I see no RTA12C that typifies the SL2000. None of the schematics state tweeter I can see.
    F1nut Posts: 49,857
    The RD0194 is not a replacement for the Peerless.
  • CH46E
    CH46E Posts: 3,579
    :( oh well. Guess I'll put them in my RTA11T then. :) Not a lost cause anyways.
    Thanks guys
    F1nut Posts: 49,857
    They will definitely work in those speakers.
