Audio nuggets YOU have learned along the way...
steveinaz
steveinaz Posts: 19,522
edited August 2018 in The Clubhouse
Disclaimer: This is strictly a personal findings, "in my opinion" type thread. Post up an audio nugget that you have learned, that may or may not fly into the face of audiophile conventional wisdom.
Here's mine:
Cables (again, in MY experiences)
Cable cost versus performance; do you get what you pay for? Maybe. Cables flavor the sound dependent upon materials, and topology. Flavor is an extremely subjective thing, and everyone has their preferences, as well as synergetic influences based on associated equipment. What if it's true that you actually prefer the tonal flavor of a less expensive cable? Quite possible; in fact factual for me on a few occasions.
The nugget? Don't make cost a priority when selecting cables. Bigger isn't always better. As long as a cable is well constructed with quality components, and spec'd for the purpose, never count out the value giant.
POST A NUGGET--
«134
  • Conradicles
    Conradicles Posts: 6,048
  • stainless0steel2
    Spiking your speakers is definitely a game changer.
    The Night is Dark and Full of Terrors
    Viking64 Posts: 6,707
    NOT all remastered CDs are an improvement over older versions.
  • chumlie
    chumlie Posts: 8,658
    Quality jumpers beat stock brass on speakers.
  • kevhed72
    kevhed72 Posts: 4,966
    You have a great sounding system at a big discount if you are willing to buy used. Also, there are alot of great, older components out there so the newest version of something may not actually sound better.
    SCompRacer Posts: 8,363
    edited August 2018
    Room. Period.
    Warning, multiple nuggets in one post but they are related.
    Just to expound on the quote, acoustic treatments and speaker placement. Just because your speakers are rated 25Hz - 20kHz +-3dB does not mean they play 25Hz - 20kHz +-3dB in your room. Speaker placement and treatments can level out frequency nulls and spikes. Most rooms not designed for audio won't even get close to +- 3dB response, but you can balance it to a more acceptable range.
    Large spaces may need subwoofers to improve the low bass. This of course is music dependent. Consult a musical instrument frequency chart and sweep your room to see if you are hearing or missing something.
    nooshinjohn Posts: 25,135
    Tubes rule...
  • Polkitup2
    Polkitup2 Posts: 1,620
    A 10/2 dedicated circuit sounds better than a 12/2 circuit. Also, check that circuit is actually off before working on.
  • motorstereo
    motorstereo Posts: 2,053
    Stacked SDA's do not sound good >:)
    pitdogg2 Posts: 24,633
    Polkitup2 wrote: »
    Now that just takes ALL the fun out of it !
    If you haven't welded at least one screw driver shaft to a metal box then you have no idea what life is allll about. The best ones are when you go to pull the shaft off the box and come away with just the plastic handle woohoo dat is lively :D:D:D
  • Willow
    Willow Posts: 10,884
    Clean out your ears every once in awhile.
  • lightman1
    lightman1 Posts: 10,776
    Willow wrote: »
    What? Speak up!
    mhardy6647 Posts: 33,095
    Trust your ears and listen to as much as you can.
    Listen to as much live music (preferably unamplified) as possible, too.
  • marvda1
    marvda1 Posts: 4,881
    if a speaker isn't tonally correct you can stop right there and move on.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • Airplay355
    Airplay355 Posts: 4,298
    Don’t send your sub signal below it’s tuning point :D
  • mlistens03
    mlistens03 Posts: 2,767
    1. Good speakers don’t sound good without good equipment behind them.
    2. Do your best to test used gear before buying.
    3. There is good sound for EVERY budget, A.K.A. Audio is not just for people with deep pockets.
  • verb
    verb Posts: 10,176
    Trust the opinions of Polkies. They’ve probably been there done that before.
    Tony M Posts: 11,022
    Humidity in the air changes soundwaves from speakers.
    NEVER use expensive speakers to test a yard sale receiver purchase! :o
    Try not to let electronics sit unplugged or unused for a long period. Some quit working while idol.
    Look around in your area ALL THE TIME and you'll find affordable audio stuff every once in a while. ;)
  • verb
    verb Posts: 10,176
    All good advice @Tony M I’ve got an SAE amp that’s been sitting in the box for years. Eventually I want to use it for my garage setup. Any startup advice?
    txcoastal1 Posts: 13,134
    I learned Nelson Pass is a hack
    verb wrote: »
    Use cheap speakers to start with. I hope it starts working from the get-go. SAE gear is pretty good aren't they?
  • machone
    machone Posts: 1,484
    Like others have said.
    Fix the room first.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Toolfan66 Posts: 16,958
    Larry's Rings. ;)
    Vinyl Death Grip. ;)
  • rpf65
    rpf65 Posts: 2,127
    Ignorance is much less expensive.
    edited August 2018
    NEVER, EVER allow anyone to carry your prized Tyler Lindbrook speakers down a flight of stairs. I wish I could find that picture....
    Post edited by nooshinjohn on
    Or across a concrete drive way. But I think that was the owner of the speakers who had a person taking his picture not knowing he was about to trip. Caught him in motion heading down. :o
  • Hermitism
    Hermitism Posts: 4,205
    Don't drive a Miata 120 miles to pick up an AVR, only to find it won't fit.
    Always bring a moving blanket to a potential used purchase. @Tony M
    edited August 2018
    The old saying goes as we age, the first to go is the memory. :#:/:)
    P.S. I now have 2 blankets in my trunk. ;):p
  • rpf65
    rpf65 Posts: 2,127
    Hermitism wrote: »
    Never drive a Miata.
