Interconnect cable for Polk SDA II
I am making new speaker cables for my Polk SDA II's and wondered what is the optimum length interconnect cable if the speaker cables are 9.5' long? I would think you would want the interconnect cable length as close to the speaker cable length as possible. I have never seen the factory cables for these speakers so I don't even know what length they were.
    F1nut Posts: 49,805
    The original SDA cables were a minimum of 20 feet long, some longer. However, there is no optimum length, so make them as long you need them to be.
  • Scott99
    Scott99 Posts: 33
    I would think excessive changes to the length of the interconnects and speaker cables could affect timing of the SDA. If the original interconnect cable was a minimum of 20'. What was the length of the speaker cables that came with the SDA's? Assuming they came with the speakers.
  • ken brydson
    ken brydson Posts: 8,650
    Speakers never come with cables unless we're talking HTIB...
    F1nut Posts: 49,805
    It came that length in a cover all bases way. 20 feet is way more than most people would require.
  • Scott99
    Scott99 Posts: 33
    Ok, thanks. I will stick with my theory that the interconnects should be as close as possible to the length of the speaker cables just in case it makes a difference. Thanks again guys for the information!
    F1nut Posts: 49,805
    The length doesn’t make a difference. The quality of the cable used does.
    pitdogg2 Posts: 24,582
    ^^^^^^^^THIS^^^^^^^^^^^
  • FestYboy
    FestYboy Posts: 3,861
    Remember, the signal is traveling the speed of light... 2.036494e−8 of a sec for those 20ft
  • FestYboy
    ^ for those not familiar with scientific notation, that number reads 0.00000002036494 sec.
    Viking64 Posts: 6,693
    FestYboy wrote: »
    Well, that clears things up a whole bunch. :o:p
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited August 2018
    In most cables electrical signals travel at about 2/3 the speed of light. The electrons inside the metal move at a snail's pace called the drift velocity. They don't have to move very far until they bump into another electron, which in turn bumps against another electron. Kind of like a line of tumbling dominoes.
  • FestYboy
    Ok, so that makes it: C=y+(.5y)
    3.054741e-8 seconds.
    Point being: you can't detect the difference, even at 10 times that length.
  • Scott99
    Scott99 Posts: 33
    Well there are several other things to consider. You would not make your left speaker wire 5' long and your right 20' long. The longer cable would have added resistance, more length to be exposed to different types of interference, difference in capacitance, etc. Especially when lower quality materials are used to make the cables the less of it you want in the signal path. Most of us take great care to make sure all our speaker drivers are getting the same quality signal. Why would we not want to make the same considerations with our SDA drivers?
    F1nut Posts: 49,805
    We have been talking about cables of equal side to side length.
  • Scott99
    Scott99 Posts: 33
    My original question was asking "What is the optimum length interconnect cable if the speaker cables are 9.5' long?" The way I understand it. If you have 9 foot speaker cables and a 20 foot interconnect cable. Your SDA drivers have the equivalent of 29 foot speaker cables and your other drivers have 9 foot speaker cables powering them. I would think we would want to try and make the interconnect cable as short as possible to try and get the same quality audio signal to all drivers.
    F1nut Posts: 49,805
    You're over thinking it. The difference between 9.5 and 20 feet is not going to affect the sound, the distances are too short. Therefore, the optimum length is whatever you need it to be.
  • FestYboy
    See my post on August 3rd.
  • dc270
    dc270 Posts: 1
    Could a replacement cable be made up from coax cable, high grade solid silver center conductor type used in head end work??
    F1nut Posts: 49,805
    Hell NO!!!
  • verb
    verb Posts: 10,176
    Hell NO!!!
    Don't worry, others will opine. That's just Jesse's way of saying "Welcome to Club Polk!" :smile:
    F1nut Posts: 49,805
    No, that's me saying hell no to his question.
    audioluvr Posts: 5,438
    dc270 wrote: »
    I suppose you could make one out of rebar too but why?
    audioluvr wrote: »
    dc270 wrote: »
    Geesh don't give'em any idea'rs
