Magnifi One - can't sync sub
Hi everyone, just got the magnifi one, like it so far - sound bar works fine, but I can't seem to sync the wireless sub. I've tried countless times following the instructions.
1. pressed the sync button on the back of the bar for 3 secs
2. waited for fast flashing
3. plugged in the sub
4. light on sub goes from green and then straight to red and then off
5. light on the bar is stops flashing
I even tried holding the sync button after the 3 secs and powering the sub, but same result.
Only time I can get the sub to flash green for longer (about 6-8 secs), is when I leave the sub plugged in and then press and hold the sync button on the bar. But it eventually the green flashing stops, goes red and then goes off.
I also disabled the wifi in the house when I tested to make sure there was no interference.
Anyone else come across the same issue and how did they resolve it?
Answers
  • KennethSwaugerKennethSwauger Moderator Posts: 6,537
    Hello,
    Welcome to Polk's forum. Let me check with Polk and I'll post their response.
    Cheers, Ken
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
    Here are some instructions that should help:
    The SurroundBar bar and wireless subwoofer come
    from the factory preset to work together. If the wireless
    subwoofer stops receiving an audio signal, follow these
    instructions to re-establish the connection.
    Move the subwoofer as close to the bar so you can reach them simultaneously.
    1. Make sure to have the bar on and playing audio.
    2. Unplug or turn off the subwoofer’s AC Mains switch.
    3. Press and hold the SYNC button on the back
    of the bar for six seconds (6) seconds.
    Continue to hold the button down during this synching process.
    Do not let it go!!!
    4. After 3 seconds, turn on the subwoofer’s AC Mains switch and continued to hold for an additional 3 seconds. (6 seconds total for this process.)
    When the subwoofer LED turns solid green the bar and subwoofer are connected and ready to use.
    5. The LED on the back of the bar will blink,
    indicating that the bar and the subwoofer
    are ready to be connected.
    Let us know if you are still having problems.
    Regards, Ken
  • kc2golfkc2golf Posts: 3
    Hi Ken,
    I followed the instructions, but the led on the sub goes solid green for ~1 sec, then blinks green, then goes red and then goes off.
    I repeated it a few times, but I get the same result.
    I also tried the original procedure after the one you provided, but all of them end with a red light and then off.
    Anything else I can try?
    Thanks,
    Hello,
    Give Kim Jasper a call at 1-800-377-7655 extension 5208 he will get you straightened out.
    Cheers, Ken
    Looks like I got a bad unit. Kim advised me to return it and ended up going another new unit that synced instantly.
    Thanks Kenneth for the assistance.
    I'm glad he was able to help! Enjoy!
  • Arizona2018Arizona2018 Posts: 1
    c0imy3jma8za.jpg. I have two of these Soundbars can I sync them together?
  • JamesVJamesV Posts: 4
    Bought one today.. Sub is dead.. Will go back to Bose
Howdy, Stranger!
