Peerless corrosion??
So I picked up a pair of really clean Monitor 4’s today for a song. They were missing one MW6500 but I had some spare 6502’s that I loaded in them for testing. They sound great, but while cleaning them up I popped the drivers and I find this white stuff on the backs of the tweeters. It’s all over the magnets and backplanes. It was actually coming out around the screw holes as well. Flakes off when scrubbed, doesn’t burn the flesh like battery acid... :D It doesn’t show up anywhere else in the cabinets. Thoughts? What is it?
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (3x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    F1nut Posts: 49,842
    Mortite gone bad.
  • JayMX
    JayMX Posts: 436
    Mortite gone bad.
    These have regular gasket material like I’ve seen in other cabinets. Isn’t Moretite usually found squished between the drivers and the MDF? Was it employed in conjunction with the closed cell foam gaskets? This stuff reminds me of battery acid corrosion, minus the burn. Or maybe salt, I didn’t dare taste it though...
    xschop Posts: 4,721
    SnO2
    F1nut Posts: 49,842
    JayMX wrote: »
    Mortite gone bad.
    Just a guess. I've seen that multiple times, really not sure what it is.
    F1nut Posts: 49,842
    xschop wrote: »
    SnO2
    That very well could be it, makes the most sense.
  • mlistens03
    mlistens03 Posts: 2,767
    I have a Kenwood woofer that has the same thing, but not nearly as bad. I believe it to be oxidation of some kind, but I really do not know.
    mhardy6647 Posts: 33,080
    Looks like it's beenin a very damp location for quite a while.
    Baltimore (or New England) basement?
  • westmassguy
    westmassguy Posts: 6,850
    They're 4s and are ported, so good gaskets or no, moisture will get in. the front's should clean up nicely. A prescription bottle cap will cover the silk dome perfectly, allowing you to clean off the corrosion, lightly sand and then hit them with some Krylon. For the rear, a soft brass parts brush and some clear lacquer perhaps.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
