Carver 4.0t or Acurus A250 or Parasound 2250 v2
CH46E
What would you take to run RTA12B?
Carver 4.0t or Acurus A250 or Parasound 2250 v2 22 votes
None of the above is not a choice...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
https://www.audiogon.com/listings/lis9004a-parasound-halo-a-23-solid-state
https://www.audiogon.com/listings/lis9019j-musical-fidelity-a-3-amp-solid-stateThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Acurus A250nooshinjohn wrote: »None of the above is not a choice...nooshinjohn wrote: »
I beg to differ on your first statement, John. Take into consideration the allowed budget. Then maybe ask what other gear is upstream and downstream. Ask before you judge.... Then offer guidance. -
Acurus A250Dang it! You said "not" a choice.... I'll show myself out...
Holy crap! Wisdom from Russ...
Like manna from heaven, happen rarely, and when it does, you notice"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
For the 12b's.....Carver or the Parrasound. With some weight on the Parrasound side.HT SYSTEM-
lsi 9's -
I have the Parasound now but kind of itching for something else. I have not heard that Carver 4.0t but i have heard the Silver 7 tube amp and loved it. The 4.0t was transfer function based on the Silver 7. Was hoping it might sound similar.
I have not heard any Acurus amp, but hear good things about them. -
The m4.0t sounds nothing like the silver 7The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Parasound 2250 v2The Carver 4.0T is the same as a TFM45 both long in the tooth and unless they have been recapped well past the due date for that.....
I run Carver TFM 45 and a TFM 25 both completely recapped and upgraded by Roland and Bob Carver.
I have heard both the Silver 7 and 9 neither the 45 or 4.0 sound like them. -
Wanna trade the TFM45?
Carver 4.0tI must say, I really do like the combination of the M4.0t and the Polks. I've never heard the Acurus, so I can't judge it.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Carver 4.0tFor the 12b's.....Carver or the Parrasound. With some weight on the Parrasound side.
Cooter has wisdom? *falls to floor*
Shut up Russ.
Not even close.
President of Club Polk -
What speaker cables and IC's are you using for the 12b's and amps ?HT SYSTEM-
lsi 9's -
Audioquest Diamondback RCAs. . And regular speaker wire due to the long run. I have audioquest cv8 but cant use them
Could be why the Parasound isn't tickling your fancy. Hard to make judgements on amps if the cables aren't up to snuff.
How long of a run are we talkin' anyway ? 12-15 ft ?
The 12b's are on the warmer side imho, with a bit of emphasis on the lower frequencies. Any amp too warm may just bring that out too much.
The Acurus has a bit more emphasis on the lower regions which may not pair well. The Carver is more even balanced, and the Parasound isn't as warm as the earlier HCA series, which is why I'm kinda shocked you don't care for it.
See if you can move things and try your CV8 speaker cables on them, just to get an idea of the sound....and go from there.HT SYSTEM-
lsi 9's -
45 ft runs. Fished the walls up to the attic, across the room then down the wall again.
Yikes! That’s a long run of cable. Though you could probably get a spool of Blue Jeans cable and cut it yourself. -
mlistens03 wrote: »
I forgot about blue jeans! I already put some bulk wire in. Not going to be getting in yhe attic anytime soon. Have to wait until nov or dec here in FL. Too dang hot. -
Parasound 2250 v2mlistens03 wrote: »
Sissy....
You could go to have inc. and buy a spool of Canare 4s11 for like 300.00 -
That’s what Russ is for....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Acurus A250Will work for beer and smokes...
Acurus A250Not yet. Still in Iowa. Heading back to Indiana Monday. Florida has come up in conversation with home office for a big project for FDOT.....
Acurus A250Florida 40acre truckstop. Brings back memories..
Randy/Maine
