2 Channel Amp to Atrium Sub10
stretchl
I didn't have any responses from this post in Subwoofer Hookup so I'm posting here:
I'd always thought that a sub needed at least a five channel amp. But from what I read last night, in preparation for installing my outdoor speakers (a pair of Atrium 5's and a Sub10), it appears that I can use a two channel amp – one channel taking white/green and the other taking red/black with the two 5's wired per usual into those same channels. (The attached image is from Polk's manual for the Sub10/Sat30 combination.)
So two questions -
1/ Is this correct?
2/ Will my old Luxman R-115 (70w into 8Ω) do the trick? (Its specs are at https://www.hifiengine.com/manual_library/luxman/r-115.shtml) I'm not sure if the amp's 20Hz to 20kHz frequency response will be sufficient, or if it even matters.
Thanks!
So two questions -
1/ Is this correct?
Thanks!
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Polk published it, why are you in doubt?Political Correctness'.........defined
President of Club Polk -
In his defense "measure twice cut once"...besides, you know from early builds, some things were never the same
@stretchl
It may look funky, but it is pulling the left and right channel signals into the sub
If you had (2)-subs then you would go
grn/wht to left chnl sub
Red/blk to right chnl sub
Thanks. Tx.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Hey stretch,
If you don't mind once you get it all up and running, let me know how it sounds as I need some more outside bass myself.. -
I have that sub but always suspected I hooked it up wrong. Curious to know how this works out.
2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
Hey stretch,
@oldrocker I certainly will. I hope to test the set up in the next couple of weeks. Need to wait until we get the house painted (a few more weeks) before I actually install the speakers.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
JB, I’ll let you know.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Thanks! JB is actually my nickname. Even my wife calls me that.
I go with Jaybeez on forums as Jaybee is taken already on most of them.
Thanks for the updates whenever you get around to it.
BTW, love your website. My wife is a photographer. At West Coast School as we speak.2 Channel "Polk" Room:
WiiM Mini
Love your emoji here!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
