2 Channel Amp to Atrium Sub10
I didn't have any responses from this post in Subwoofer Hookup so I'm posting here:
I'd always thought that a sub needed at least a five channel amp. But from what I read last night, in preparation for installing my outdoor speakers (a pair of Atrium 5's and a Sub10), it appears that I can use a two channel amp – one channel taking white/green and the other taking red/black with the two 5's wired per usual into those same channels. (The attached image is from Polk's manual for the Sub10/Sat30 combination.)
So two questions -
1/ Is this correct?
2/ Will my old Luxman R-115 (70w into 8Ω) do the trick? (Its specs are at https://www.hifiengine.com/manual_library/luxman/r-115.shtml) I'm not sure if the amp's 20Hz to 20kHz frequency response will be sufficient, or if it even matters.
Thanks!
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
    F1nut Posts: 49,787
    Polk published it, why are you in doubt?
    txcoastal1 Posts: 13,132
    In his defense "measure twice cut once"...besides, you know from early builds, some things were never the same
    @stretchl
    It may look funky, but it is pulling the left and right channel signals into the sub
    If you had (2)-subs then you would go
    grn/wht to left chnl sub
    Red/blk to right chnl sub
  • stretchl
    stretchl Posts: 1,334
    Thanks. Tx.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • oldrocker
    oldrocker Posts: 2,590
    Hey stretch,
    If you don't mind once you get it all up and running, let me know how it sounds as I need some more outside bass myself..
  • Jaybeez
    Jaybeez Posts: 748
    I have that sub but always suspected I hooked it up wrong. Curious to know how this works out.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • stretchl
    oldrocker wrote: »
    Hey stretch,
    @oldrocker I certainly will. I hope to test the set up in the next couple of weeks. Need to wait until we get the house painted (a few more weeks) before I actually install the speakers.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    Jaybeez wrote: »
    JB, I’ll let you know.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Jaybeez
    Jaybeez Posts: 748
    edited June 2018
    stretchl wrote: »
    Jaybeez wrote: »
    Thanks! JB is actually my nickname. Even my wife calls me that.
    I go with Jaybeez on forums as Jaybee is taken already on most of them.
    Thanks for the updates whenever you get around to it.
    BTW, love your website. My wife is a photographer. At West Coast School as we speak.
    WiiM Mini
  • stretchl
    Love your emoji here! :)
    - Isaac Asimov
    Hi-Fi
    Visuals
