sub no sound
lucifershand
the lights are on but no ones home...
Sub works for test tones from receiver but produces no sound during regular watching or listening. have tried all the settings any thoughts?
thanks
thanks
Need more info....what sub ? How's it hooked up and to what ? Are you playing material that has low freq. sounds ? What settings are you using on the sub...receiver ?HT SYSTEM-
lsi 9's -
sub is psw111 off of pioneer vsx-831 subwoofer cable lfe
i have played all sorts of different material through the sub sub is set to on 0 phase dials around half way up on each and have cycled through what id say are all of the settings on the receiver ive been trying to figure it out for a couple of weeks and am out of ideas -
To test the subwoofer first turn the sub's volume all the way down and remove the sub cable from the receiver. Then connect the sub cable to either the right or left audio output of your DVD/CD player and begin playing a CD and slowly turn up the volume on the sub. It should make plenty of bass at a low setting.
