Magnifi Max sound bar amber light blinking
geedee
the speaker is not responding to anything. i have pulled the plug, pressed the reset button, the subwoofer sync button, the mute button, the input button. nothing is working. how can i get it to start working again?
Hello,
The best thing to do is call Polk at 1-800-377-7655 select option 1 and have the serial number handy when you call. -
ok thanks. called them. they said sound bar has gone into PROTECT MODE for some reason.
It is very unsettling that month old $500 sound bar has become useless without extensive use. -
Something probably just failed. Tends to be the norm with electronics, unfortunately.
Did you push it hard before it started? That could have caused a short in the subwoofer driver and caused the amp to go into protect.
