Magnifi Max cannot detect 5 GHZ NETGEAR Router
damiena
Magnifi Max cannot detect 5 GHZ NETGEAR Router R6220, it can detect and connect to 2.4 GHZ of the same router.
Try unplugging for a minute, power on, and wifi reset. Are any devices in your place running on the 5G side of the router?
Nevermind...
Nevermind...
...that seems even more intriguing than the post you were going to add.
