Peerless smooth face vs textured face?
So I picked up this pair of 10A’s this week from the original owner for under $100. Serial numbers are three digits apart. Pretty pleased with them. They appear to have two different Peerless tweeters in them though. You can kind of see it in the photo, but the one on the left has a smooth face and the one on the right is textured - almost like it was powdercoated. The smooth faced driver seems to have a little more sizzle and detail. Also I notice that the fuses are not matched. I speculate that one of the original tweets was blown and replaced at some point. I seem to remember reading somewhere here that there is a difference between the smooth and textured faces but I can’t find it... Enlighten me oh ye wise ones?
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (3x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    F1nut Posts: 49,828
    If one fuse is of higher value then that tweeter will be duller.
  • FestYboy
    FestYboy Posts: 3,861
    Possibly the MCM copy?
  • JayMX
    JayMX Posts: 435
    Didn’t think of that. I will find a matched set.
    FestYboy wrote: »
    Any idea if the MCM had any telltale markings?
  • FestYboy
    I've never had one in my hands, sry.
  • Faustin
    Faustin Posts: 1,149
    Did you pull them out to see if there are any labels on the back of them? What size fuses are in them?
  • JayMX
    JayMX Posts: 435
    So one fuse was 8A and the other was 2A... Now have matching 2A fast blows loaded. I think the smooth face is a replacement as it was in the cabinet with the 8A fuse. They are definitely different though. Smooth face just has a couple of numbers on the back. Textured says made in USA and has more numbers.
    F1nut Posts: 49,828
    The smooth face is the original Peerless, the other is a replacement.
  • delkal
    delkal Posts: 764
    JayMX wrote: »
    Those are both high. You are supposed to use a 1 amp fast blow.
    F1nut Posts: 49,828
    ^ Good catch ^
  • JayMX
    JayMX Posts: 435
    But 2A should make it louder, right!?! ;)
  • delkal
    delkal Posts: 764
    JayMX wrote: »
    Yes it would be louder........till you start seeing smoke. Not sure what the previous owner was thinking with an 8 amp fuse. I guess they all look the same?
    A lot of people disable the polyswiches on the newer models with a jumper or resistor. So if you are careful / sane you really don't need the fuses. But I still use mine for a little extra insurance.
  • JayMX
    JayMX Posts: 435
    @delkal - I was kidding haha, ever since inadvertently I toasted a RDO 194, I am verrrrry careful. On the original topic, it’s interesting that the smooth face tweeter sounds just a bit better/clearer. I may update the crossovers before trying to find another smooth face. But all in all they’re great speakers. Thanks everyone for the insights.
  • machone
    machone Posts: 1,480
    Why would a higher value fuse be duller?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    pitdogg2 Posts: 24,606
    machone wrote: »
    Higher resistance is my guess
    F1nut Posts: 49,828
    Right, the higher the value, the greater the resistance.
