C.H. Diamond 6SN7 Tube Preamp
    txcoastal1 Posts: 13,132
    kharp1 wrote: »
    I would have to believe that a pre with dual outputs would have some resistance added. Been several years since I was in that class, and, we don't do much of that here. Lot of plug and play components (proprietary) and logic changes (which is what we do mostly).
    Not saying that a splitter won't work, we all know it does, but, I think proper utilization would require modest circuit changes.
    I agree there will be variances pending on connector and cable materials and structure etc
  • marvda1
    marvda1 Posts: 4,873
    edited March 2018
    this is from a highly thought of company.
    https://www.ebay.com/itm/YS-Audio-SYMPHONIES-PLUS-R-Remote-Tube-Preamplifier-/190905561201
    they make a fully balanced pre at about $998
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • mikeyb128
    mikeyb128 Posts: 2,885
    I’ve always preferred my sub wired off of the amp using high level speaker terminals on the sub (for 2 channel). And you have the fun of making a nice custome cable with fancy tech flex. JL and REL swear by it, subs are easier to blend with the mains this way. Less delay as well.
    2 channel:
    Theater:
    Agree, option I posted was to limit cables gear and space for desk top
  • kharp1
    kharp1 Posts: 3,453
    Which was kind of my point, you don't have to, but, to do it properly resistance should be added.
  • mikeyb128
    txcoastal1 wrote: »
    Ohhhhhhh, desktop rig. Got it.
    2 channel:
    Theater:
    mhardy6647 Posts: 33,049
    kharp1 wrote: »
    I think a buffer (active circuit with impedance matching) is the 'best' way to do it, FWIW.
    Clipdat Posts: 12,608
    Anyone have any listening experience with this preamp?
    marvda1 wrote: »
    edited March 2018
    kharp1 wrote: »
    Sorry, this was a dumb response that I posted :( I would've edited it, but I missed the 60 minute window.
    Suffice it to say that either passive (resistive) or active matching (resistors or a cathode follower or buffer) represent good ways to optimize splitting line-level signals. :|
    Sorry!
  • kharp1
    kharp1 Posts: 3,453
    kharp1 wrote: »
    Sorry!
    You make a good point, I wasn't stepping it out any further than is a splitter the best way to do it. Resistive would work, but, an active buffer stage would be better.
    Urge to buy the YS-Audio SYMPHONIES PLUS-R is rising.
  • marvda1
    edited March 2018
    Clipdat wrote: »
    looks like the two knob version is the best.
    forget this, thinking about another pre.
    Puritan PSM156
    Link? I was just looking at this one: https://www.ebay.com/itm/190905561201
    marvda1 wrote: »
    Clipdat wrote: »
  • marvda1
    Clipdat wrote: »
    marvda1 wrote: »
    Clipdat wrote: »
    my bad, thinking about another preamp.
    Puritan PSM156
    This preamp looks pretty nice as well, built in phono stage: http://www.doge.audio/products/doge-8-tube-preamplifier/doge-8-clarity-2017-edition/
    What's up with those silver shields that go around the tubes?
  • kharp1
    kharp1 Posts: 3,453
    Dampers/cooling devices.
    Viking64 Posts: 6,693
    Clipdat wrote: »
    I love DOGE!!!! :p
