Polk S20's
    F1nut Posts: 49,806
    You should have returned that 4.28 lb. Yamaha. 4.82 lbs.!!!
  • Synomenon
    Yup, ended up returning that as well after I got a great deal on a Marantz NR1508. Spec.-wise though, the Marantz would have pushed less to the S20 (55W from the Yamaha and 50W from the Marantz).
    F1nut Posts: 49,806
    It's not about watts, it's about current.
    I've driven the S20's with an 8wpc vintage Pioneer integrated, but it's got balls.
  • Synomenon
    Where do manufacturers list the current in their specs.? I've only seen wattage listed.
    F1nut Posts: 49,806
    edited February 2018
    That is not easy to find until you get into the higher end gear. However, a good sign that the piece has a respectable current (amperes) rating is if the wpc rating doubles from the 8ohm rating to the 4ohm rating.
    Even if it doesn't double, but is rated to drive a 4ohm load that is a very good sign.
  • Synomenon
    So this is what Crutchfield told me about my Marantz NR1508:
    "The NR1508 is rated at 50W RMS for 8-ohm speakers. If the speakers have 4 ohms of impedence, the RMS wattage would be twice that (100W)."
  • rooftop59
    rooftop59 Posts: 7,981
    That marantz is a good piece, and will provided probably a little more than 50 wpc into 8 ohms, and will stay very close in surround mode. It has a nice full, slightly warm sound that should pair nicely with the polka!
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 49,806
    Synomenon wrote: »
    They are wrong! That Marantz is not rated to drive 4 ohm loads and therefore is incapable of doubling its output.
    Clipdat Posts: 12,608
    Right. They are just speculating. Incorrectly.
    Comon Crutchfield, try harder.
    Synomenon wrote: »
