Wall mounting a LSiM 706C
Earthy
Earthy Posts: 488
edited January 2018 in Speakers
Looking for an idea. Thinking of a wall mounted shelf that can hold the 46lbs and look good. It would need support from below as the TV would be just above it.
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
  • afterburnt
    afterburnt Posts: 7,892
  • DaveHo
    DaveHo Posts: 3,481
    rpf65 wrote: »
    I used this same mount for my wall mounted turntable platform. I can vouch for its quality. It's solid.
  • Earthy
    Earthy Posts: 488
    Nice, I see it on Best Buy for $35. Hard to beat. My speaker centers about an inch from a stud. Might need to put a 3/4 hardwood board across three studs so the mount can be centered and anchored well. I should be able to get long lag bolts in the center stud. Thanks all!
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • Earthy
    Earthy Posts: 488
    I stumbled across this one on Amazon. Might work better for me since it's two brackets. Rated for 110lbs so no issue there. http://a.co/h4HhLHY I can get it faster than the other one so worth a try at $29
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • rpf65
    rpf65 Posts: 2,127
    I use the one I suggested for my LSI M706C. Build quality is very good, mounting options seemed a little bit more versatile than the style you suggested.
  • Earthy
    Earthy Posts: 488
    Did you add a shelf? Are there options to anchor a shelf to the arms? Looks nice but over a week to get.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • GlennDog
    GlennDog Posts: 3,087
    Earth,
    What's a fair price for a "used" 706 center? and how do you rate it?
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Earthy
    Earthy Posts: 488
    With all the recent adorama sales, I think new ones can be had for $5-600. I have not sold used speakers before. Usually give them away or store them. I am not the expert at rating speakers. Hopefully someone will chime in. Perhaps you should start a new thread.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
