Wall mounting a LSiM 706C
Looking for an idea. Thinking of a wall mounted shelf that can hold the 46lbs and look good. It would need support from below as the TV would be just above it.
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
big lag bolts
I used this same mount for my wall mounted turntable platform. I can vouch for its quality. It's solid. -
Nice, I see it on Best Buy for $35. Hard to beat. My speaker centers about an inch from a stud. Might need to put a 3/4 hardwood board across three studs so the mount can be centered and anchored well. I should be able to get long lag bolts in the center stud. Thanks all!Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
I stumbled across this one on Amazon. Might work better for me since it's two brackets. Rated for 110lbs so no issue there. http://a.co/h4HhLHY I can get it faster than the other one so worth a try at $29Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
I use the one I suggested for my LSI M706C. Build quality is very good, mounting options seemed a little bit more versatile than the style you suggested.
Did you add a shelf? Are there options to anchor a shelf to the arms? Looks nice but over a week to get.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Earth,
What's a fair price for a "used" 706 center? and how do you rate it?AC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
With all the recent adorama sales, I think new ones can be had for $5-600. I have not sold used speakers before. Usually give them away or store them. I am not the expert at rating speakers. Hopefully someone will chime in. Perhaps you should start a new thread.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
