Magnificent mini subwoofer not connect
kobid
Hi
Please help!!!! My subwoofer sudnly stop working, I'm following all the instructions to fix it
Press on source button and Bluetooth for 3 second and then on sync button on sub but nothing fix it.
It's worked perfect for 3 month and stopped work.
The sound bar work fine.
Any suggestions? Please help I buy it from Amazon and the local Polk not accept the assurance.
Best Answer
Yes I'm from israel
Answers
Hello,
Welcome to Polk's forum. It would be best to contact Polk at: 1-800-377-7655 select option 1 for help. They'll be able to get it working for you.
Regards, Ken -
Unfortunately they not
Can you explain? Are you living outside the U.S.?
In that case send an email message to: Ken.Carter@soundunited.com
Thanks a lot, I will send him.
