Another off my bucket list - heard Focal Utopia Grande EM
  • K_M
    K_M Posts: 1,627
    K_M wrote: »
    TForan wrote: »
    I still think ideally a speaker should be matched to the room size.
    Yes, having them so into a corner, and so close to back and side walls, could not even remotely be great for the sound.
    I have heard great speakers sound so-so in smaller blah rooms, and relatively average speakers really excel in bigger rooms with some thought to placement.
    In your own words....
    K_M wrote: »
    So you have the same room acoustics as he has, the same hearing and the same preference in sound and music?
    That is pretty bold, to be able to determine over the internet, what will work for other random strangers, who you have no clue about their situation or anything.
    Well played, but would you argue that speakers that size backed into the corners, would not have issues?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    K_M wrote: »
    K_M wrote: »
    TForan wrote: »
    K_M wrote: »
    Well played, but would you argue that I deflect better than the shields on the starship Enterprise and have been proven to have serious psychological issues?
    Went ahead and fixed it for you K_M.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    K_M wrote: »
    Maybe. It depends on several factors...which you were apparently aware of at one time but apparently forgot for the sake of convenience.
    I would argue that thoughtful speaker designers, especially designers of large expensive speakers, take into account the myriad of listening environments their target market might have to deal with and design speakers that will "work" in a variety of environments.
    For example, the manual for Sonus faber's Aida loudspeakers recommends a placement of at least 6.5' from side walls, at least 8.2' between speakers, and at least 8.2' between the speaker plane and the listening position. The recommended distance from the rear wall is 1/3 the room depth. Therefore, the minimum optimum size room for a pair of Aidas, according to the recommended room ratio (W:L:H) of 1.7:2.3:1 would be approximately 24' wide by 32' long x 14' high.
    I asked Sonus faber if my room measuring 21' wide by 17' deep with 10' ceiling was too small for the Aidas, and if one of their smaller speakers would be a better acoustic fit. This was their reply:
    "The room size is big enough to get the best from our Aida loudspeakers. The only suggestion is to place the Aidas along the wall 17 feet wide rather than place them along the long one (21 feet).
    And most important is to place the loudspeakers away from the back wall to get the best from the rear firing Sound Field Shaper."
    Speaker placement and room size are important components of speaker sound. We must also consider that the level and frequency of acoustic energy delivered by the speakers...and room treatments, also play important roles.
    Sonus faber Aidas (19"W x 21"D x 68"H) set up in a dealer's less than optimal audition room.
    This is a pair of Aidas owned by a Sonus faber dealer and set up in his home, with fairly close placement to the rear wall, a corner, and side wall. If I had a pair in my living room, the placement would be very similar to this.
  • DarqueKnight
    K_M wrote: »
    TForan wrote: »
    K_M wrote: »
    I recall we once a "member", who had multiple personalities, and sometimes one personality would forget what the other personality said.
  • K_M
    K_M Posts: 1,627
    edited April 2017
    So, nothing can be said for sure.
    Sadly, that is gonna have to apply to all posts.
    Are you guys sure you want to back yourselves into that corner?
    F1nut Posts: 49,842
    edited April 2017
    The corner is all yours. You painted yourself into it, you have to stay there.
  • DarqueKnight
    K_M wrote: »
    What corner are we in danger of backing ourselves into??? You are the one making absolute statements and then contradicting yourself.
  • K_M
    K_M Posts: 1,627
    K_M wrote: »
    You can not apply one set of rules to posts of people you dislike and another set to people you do like.....get it?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    K_M wrote: »
    K_M wrote: »
    "Deflector shields at maximum!!! Evasion action!!"
  • K_M
    K_M Posts: 1,627
    edited April 2017
    ZLTFUL wrote: »
    K_M wrote: »
    K_M wrote: »
    Yes! I am successfully avoiding the Hypocrite asteroid field. Warp 8!
    Fun fun!
  • mikeyb128
    mikeyb128 Posts: 2,885
    K_M wrote: »
    ZLTFUL wrote: »
    K_M wrote: »
    K_M wrote: »
    Fun fun!
    Just drop it. Jeeez
    2 channel:
    Theater:
  • mikeyb128
    Seems like one of those people that has to get the last word in no matter what.
    Sure takes a special kind of guy to marry a gal like that.
    2 channel:
    Theater:
  • ZLTFUL
    ZLTFUL Posts: 5,640
    K_M wrote: »
    ZLTFUL wrote: »
    K_M wrote: »
    K_M wrote: »
    Fun fun!
    Maybe you should just leave. CASH YOU OUSSIDE! HOWBOW DAH?!?!
  • codycatalist
    codycatalist Posts: 2,662
    ZLTFUL wrote: »
    K_M wrote: »
    ZLTFUL wrote: »
    K_M wrote: »
    K_M wrote: »
    Fun fun!
    Popcorn ready!
  • [Deleted User]
    How dare you step a toe into Mensworld. ;)
  • DarqueKnight
    edited April 2017
    K_M wrote: »
    Were you speaking of me or someone else? If your response was aimed at me, please point out where I have been hypocritical. Who are the people I allegedly dislike? For the record, there is no one on the forum that I dislike.
    I would certainly lay the hypocrite crown on your head. Weren't you the one stating one set of rules for one person then contradicting yourself by stating another set of rules for another person? When I have I done such? Again, perhaps you meant someone else? If so, when did the other person act in a hypocritical manner?
    Do tell.
    txcoastal1 Posts: 13,134
    ZLTFUL wrote: »
    K_M wrote: »
    ZLTFUL wrote: »
    K_M wrote: »
    K_M wrote: »
    Fun fun!
    Popcorn ready!
  • K_M
    K_M Posts: 1,627
    K_M wrote: »
    Do tell.
    No, sorry, was not about you.
