Man Cave Mini-HT Project
Mikey081057
Mikey081057 Posts: 7,127
edited April 2017 in The Clubhouse
I am now committed into turning my listening room into a combination listening room Man Cave Mini 5.1 HT.
Here is what I have started with
I have a Parasound P5 and A21 that i will config via HT pass through to keep together as a standalone system. This is paired with my Usher Mini Dancer-x DMD's
There is a 50" Samsung SUHD 4K tv already as well.
My TT and Marantz SA8004 along with Directv and Bluesound Node 2 will be sources of audio and video.
I am adding:
Oppo 203 4K BDP
Marantz SR5011 AVR (received today)
SVS SB 2000 Sub to replace Polk MP2K Sub
Usher BE-616 Center channel (maybe overkill but it matches the Mini Dancers) powered by a Parasound A23 that i already have.
Trying to decide on:
Rear channel speakers. Prefer wall mount somewhat thin but may wait a bit on those ( these will be driven by the AVR or I could use another A23) Thanks to @DSkip for locating 1 and helping me spend money.
How important is matching your rear channel ht speakers to your fronts? I may eventually go ceiling mounts.
Here is how it looks today:
Thoughts? Comments? Advice?
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
«13
  • hochpt21
    hochpt21 Posts: 5,423
    Wow, there is a lot of goodness happening in that room!
  • Mikey081057
    I am thinking of inviting @lightman1 down for a weekend of cable management and debauchery. I suck at cable management but both of us can handle a prime steak and some debauchery.
    My landscaping may never be the same tho.
    :D
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Fantastic vibe in that space I would bet. Looks great!
    I have Revel mains, center and sub with ceiling mounted Klipsch fronts and rears . I can hear nothing "unmatched" running 7.1 audio of any kind. My vote would be non-important. YMMV due to room differences.
  • scubalab
    scubalab Posts: 3,101
    Dayum! That's an awesome man cave Mikey!
    I'd agree with Mike (BlueMDPicker) that matching your rear speakers is not that important at all since they don't pull that much weight in HT. I'd also think the Marantz AVR would be fine powering them... unless for OCD's sake you want another A23!
  • lightman1
    lightman1 Posts: 10,776
    :D
    Sold!
  • Mikey081057
    He just needs to be careful of these in the bushes...
    you wouldn't want to pee this guy off
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Sad thing is, I have seen his cable management first hand and I wouldn't let him within 3 meters of my cables!
  • Mikey081057
    Maybe I will just hire somebody to do it while we he watches us eat and drink then.
  • lightman1
    ZLTFUL wrote: »
    Says the guy who didn't staple the romex within code to outlet or cans. And the 14-2 looked like Twizzlers going to said outlets.
  • lightman1
    An even better proposition.
  • Mikey081057
    and please nobody make any mention of using romex for speaker cable in this thread.
  • lightman1
    It's got copper in it. What's the difference?
    *lights fuse and steps away*
  • dromunds
    dromunds Posts: 9,984
    Hey, that rug looks just like a rug I had that my former girlfriend took when we split up. Wait a minute, you didn't ......
    EndersShadow Posts: 17,543
    edited April 2017
    lightman1 wrote: »
    ZLTFUL wrote: »
    And lets not even talk about using a Laser Level and making sure its... LEVEL lol.... tehehehehehe.... @ZLTFUL
    To your question Mikey, Rear and side surrounds aren't "as" important to timbre match. As to if your personal OCD requires them to be, I cant speak to.
    As long as they are a decent size speaker (IE not 2.5" drivers) you should be fine. In-ceiling or in-walls from a decent brand would work just fine.
    txcoastal1 Posts: 13,134
    lightman1 wrote: »
    ZLTFUL wrote: »
    Answer this question sir.
    Have you ever gone into someone's attic, and drilled a hole in the header and dropped a piece of romex down the wall, and fished it out, and then added a plug for someone?
  • lightman1
    edited April 2017
    txcoastal1 wrote: »
    lightman1 wrote: »
    ZLTFUL wrote: »
    That's different. He had exposed framing and was doing rough in.
    Stick that in yer pipe and smoke it, swamp-a$$......
    Codes and standards....you, of all people should know better.
    *middle finger emoji*
    lightman1 wrote: »
    txcoastal1 wrote: »
    lightman1 wrote: »
    ZLTFUL wrote: »
    I do know that...tell that to scubalab, sorry scubalab had to throw you under the bus :):pB)
  • scubalab
    Wait... What did(n't) I do Ron? And how did YOU find out?!? :p
    scubalab wrote: »
    Pics....and it happened brother. I've sent the fun police i.e. inspectors a pic of your sub install...they liked the sub, but not the unfastened romex :o:)B) ...... :D:D:D
    edited April 2017
    lightman1 wrote: »
    txcoastal1 wrote: »
    lightman1 wrote: »
    ZLTFUL wrote: »
    Code wise cr@ptard would be to install conduit or a metal wire mold...and yes I'm just a low voltage guy, but do know a little about code....and I see you tried to wave yourself from the true answer....
    "Have you ever dropped romex down a wall????? (in my best Trey Goudy voice)"
    And sir with your insults you have earned yourself a classic stink palm...see ya at LSAF ;)
    https://youtu.be/MMzd40i8TfA
  • Mikey081057
    And there goes my thread...
    Just trying to help with the basics of wiring, and screening qualified individuals who may or may not work in your home mikey ;)
  • Mikey081057
    Ron you can basically kayak to my house from the gulf coast of TX.. We can use a supervisor.
    I'd fly but my arms would get tired :|
    edited April 2017
    txcoastal1 wrote: »
    Just use all that hot air you're constantly blowing to float over there :grin:
  • Mikey081057
    txcoastal1 wrote: »
    That might be more devastating to the Gulf than the Deepwater Horizon blowout
    txcoastal1 wrote: »
    If I could fly, your windshield would be the first bird bomb I'd drop
    Hey Mikey
    Can you get above the ceiling in that room? Can you drop wire behind your rack?
    If you can, imho would use 2 Polk vanishing series speakers in that room.
    They are really good speakers, they have adjustable tweeters, have installed them several times
  • Willow
    Willow Posts: 10,882
    My manscaping may never be the same tho.
    :D
    Fixed it for you.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,354
    Cool room! I love my p5 and hope you enjoy yours... you should fill in the wall space with more vinyls though:)
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
