Clearing Learned Remote Codes Magnifi Mini
Mick_H
Somehow during set up, the channel change button on the cable remote now acts to change the source on my Magnifi Mini. Such that whenever I change channel using the channel up button the source moves from optical to aux....etc
Anyway to reset the learned remote codes on the Magnifi Mini and I can start again !
Hold the Wifi button on the back of the unit until you hear three sets of beeps. This performs a factory reset. I had a similar issue, and this cleared it up.
