Multiple LP Plays in a Row - Damage is Possible
  • lightman1
    lightman1 Posts: 10,776
    To wit......"Naw man...I know I heard the spectres voice on the intro to Brain Damage......just listen!"
  • Nightfall
    Nightfall Posts: 10,073
    Took long enough for you guys to Polkieize? this thread ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • lightman1
    Nightfall wrote: »
    We had to wait for Doc Hardy to Hardy up the thread first. A show of respect of course.
  • Nightfall
    Alright, I chose Phil Collins "Face Value" because there's not a shortage and it's a cheap record. I'm about to listen to enough Phil Collins tonight to last me a month, the same side over and over.
    afterburnt wrote: »
    nooshinjohn Posts: 25,115
    Hope you have some good booze to help you through.
  • mikeyb128
    mikeyb128 Posts: 2,885
    vmaxer wrote: »
    mikeyb128 wrote: »
    The LP I was using was the new/remastered copy of division bell. It sounds really good.
    "Sounded really good "
    Ugh.
    2 channel:
    Theater:
  • Nightfall
    I never noticed this but there's a repeat button on my TT. Why would Yamaha put a repeat button on one of their best TT's ever if repeat plays would destroy records? I don't think they would.
    I'm on the third play through of "Face Value" side A. Still sounds fine so far.
    afterburnt wrote: »
  • Nightfall
    This must be loooove, I feeeel it. This must be loooooove!
    afterburnt wrote: »
  • lightman1
    Josh is feeling the vibes now
  • Nightfall
    I can't take it anymore. I'm going to let the record keep playing on repeat and I'm going to watch (and listen!) to something else while it does its thing.
    afterburnt wrote: »
  • Nightfall
    I forgot I had this thing... Soundcraftsmen Instructional Test Record. I bought it a while ago and never played it. It looks like it's just a bunch of test tones, probably nothing like the test records we were talking about earlier.
    afterburnt wrote: »
  • Nightfall
    edited March 2017
    Alright, this is been on repeat for near 3 hours and it still sounds fine. When I pulled the record off it did not feel significantly warm either like the record in the OP, only very very slightly warm.
    I checked out the Soundcraftsmen record and it's for setting up an equalizer.
    This looks like what I want https://www.amazon.com/HiFi-News-Test-Producers-Cut/dp/B00KMCL1PE
    afterburnt wrote: »
  • motorstereo
    motorstereo Posts: 2,053
    Sounds to me like it's yet one more reason to leave vinyl behind and switch to another format.
    mhardy6647 Posts: 33,066
    Here I get a night's sleep and you guys have all the fun...
    gudnoyez Posts: 8,068
    Nightfall wrote: »
    Oh my god are you harboring a few people to torture? I mean I can't get through one song of Phil Collins let alone an album side, then on repeat oh my God the Horror. :o
    All jokes aside perhaps you got a bad pressing, it happens more often on newer pressings, I have clear, red, blue, white, yellow, no problems, but some problems such as warpage, and extreme surface noise on what appears to be a mint clean copy have only been expierenced by me with some of the newer 180 gram pressings.
    I have read a lot of complaints on the quality control of some of the newer vinyl pressings. Solution buy another copy of the same LP and see if you experience it again if so return them both.
  • Nightfall
    stones89 wrote: »
    i do believe damage can be done playing the same track over and over.
    Heretic! That's literally impossible, all vinyl records are invulnerable. ;)
    afterburnt wrote: »
    Shellac, baby -- bring back shellac!
  • dromunds
    dromunds Posts: 9,984
    You haven't seen my original copy of Jimi Hendrix's Are You Experienced that I got in seventh grade...
