Anyone use different output levels for different sources?
For me it depends on what I am doing.
Volume average,
BluRay -20db to -15db
DVD -17db to -12db
Music is Audyssey off and let it rip.
As you can see it's a different volume level for different sources. A lot has to do with the audio format of the material. BluRay tend to play louder than DVD's.
When I setup my receiver I had to dig through my notes to find my Onkyo's setup settings. My Marantz set everything way low. I did have to go into manual speaker level and move up the front and center by 3db, rears by 4db and front high by 5db to get them to where the Onkyo set them at. now all is perfect.
I did find a problem with my sub. I run it with 2 ports open. Audyssey kept setting the sub @ -12db. HSU said to plug a port and flip the switch to 1 port open, I ran Audyssey again and it set it at 0db. perfect. un plug it flip the switch back to to ports open and add 5db to it...
Now with my new S60 I might have to pull the Onkyo out of the bedroom and hook it up downstairs again just to run Audyssey for proper settings.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
You have to change the volume level when you change the source.
What are you talking about? Try to stay on the subject.Denon X1200W
Sony BDP S-590
Mains Signature S60
Center Signature S55
Surrounds Polk RTi-4 -
WVHillbilly wrote: »
Everyone is telling you the same thing I am and you're not listening. So, who doesn't understand?Political Correctness'.........defined
President of Club Polk -
Hillbilly...have a looksee at @mrloren post. I said the same thing but he made it clear and concise.
The answer to your question has been given three times. -
Volume average,
DVD -17db to -12db
When I play audio through the Smart TV using the optical cable, to get the right fidelity to the speakers before I amplify I have the levels to the mains set at +7.5. Any lower than that and the music is muffled and not right.Denon X1200W
Sony BDP S-590
Mains Signature S60
YOU
Denon X1200W
Sony BDP S-590
Mains Signature S60
WVHillbilly wrote: »For me it depends on what I am doing.
Volume average,
DVD -17db to -12db
Well, that certainly helps to explain the original post.
Three 20 amp circuits. -
Right, good luck. You're as thick as they come.Political Correctness'.........defined
That is, in a nutshell, the same thing I was helping you with. Bluefox as well. -
Volume average,
DVD -17db to -12db
Yes, different sources, depending on your playback, can be affected by AVR levels before playback. I was wondering who uses this concept to maximize fidelity.
That being said, Playing back through the Sony requires different main setting, just through the main menu for speaker levels for maximum fidelity. I hope this is more clear now, this applies more to people who do not use room correction for music playback.Denon X1200W
Sony BDP S-590
Mains Signature S60
I don't use room correction through an AVR. The only DSP I have is with the open baffle Emerald Physics speakers I have.
My turntable has a lower output voltage than the Oppo I'm using. How do I compensate? I turn the volume up higher. If that's not the answer than I have no idea what you're talking about. This thread is making my head spin.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Using this and understanding how this works, enables anyone who is trying to get the most from their system--achieve their goal without a lot of tone clutter in the signal path.
Getting the concept right and paying attention to what you're doing, thinking it through--will make for a better sound.Denon X1200W
Sony BDP S-590
Mains Signature S60
What in the world are you on about?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
You might not have to do any level compensation for your turntable.
I never said you did. Your set up is different than mine. Not everyone has the expensive equipment you have.Denon X1200W
Sony BDP S-590
Mains Signature S60
I have a shartload of passive pre-amps that have tone controls. That doesn't mean I have to use them.
I don't use tone controls either but if my levels were not set correctly from the get-go--then I might be temped to use them.
And I'm not talking about the volume control.Denon X1200W
Sony BDP S-590
Mains Signature S60
So this phenomenon is only with entry level electronics? My setup is okay but in the grand scheme of things it's entry level. Can you link to any webpages or forum threads that discuss this because I think you're just confusing everyone. Different output levels for different sources... most sources don't have adjustable output levels. I once had a Yamaha CD player back in the day that had an adjustable output level. Actually Oppo has a volume control too but I never use it, I stick with a fixed output level.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Gee, I didn't know this would be so tough to understand---NEVERMIND---HAHAHAHADenon X1200W
Sony BDP S-590
Mains Signature S60
WVHillbilly wrote: »Yes, different sources, depending on your playback, can be affected by AVR levels before playback. I was wondering who uses this concept to maximize fidelity.
This is legitimately funny. I don't even know if you know what you mean.
So if I adjust the output level of different sources before they're affected by AVR levels after playback when not using YPAO with the main setting through the main setting I can get MAXIMUM FIDELITY? Sign me up!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Run Forrest run!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
I know what I mean because my playback is correct.
The proof is in the music playback.Denon X1200W
Sony BDP S-590
Mains Signature S60
Am I drunk again?Denon X1200W
Sony BDP S-590
Mains Signature S60
I just fired up my rig and I'm only getting 75% of the maximum fidelity. Shoot. Can you tell me how to adjust my playback main setting output before the AVR levels affect everything? I'd like to be closer to the maximum fidelity.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
He's talking about setting different speaker levels in his AVR for each source. For example, he might set one source to play back at +5dB and another to play back at -2dB. However, that is completely unnecessary because one can simply adjust the volume using the volume control and obtain the same result. Easy peasy lemon squeezy, maximum fidelity.Political Correctness'.........defined
Yo! J! Just set the kinibbler pin output to 38% from the Schwartz transport to the fan motor. Prollem solved
Have you thought of using Atmos speakers on your ceiling fan? I bet it will make those helicopters sound like the are flying right over your trailer park!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I'm frikkin' tearing up over here.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
No, it does not achieve the same result. Not in my system.Denon X1200W
Sony BDP S-590
Mains Signature S60
