Need advice on receiver purchase for SDA 2 speakers
I acquired a pair of SDA 2 speakers from a family friend many years ago and have now just got around to becoming interested in them. From what I have read, they are great vintage speakers. But here's my problem. I don't have a receiver for them. I've been looking at my local Best Buy Magnolia store at mid level receivers but I have no clue what I'm looking at. And neither do the employees there it seems. Does anyone have any recommendations for a receiver for me. I'm looking to spend around a thousand dollars max. I'm interested in modern receiver's for the wireless features they have compared to vintage receivers. Any help / advice will be greatly appreciated!
My current setup:
- Yamaha Aventage 9.2 channel 1260 Watt receiver; model RX-A2050BL
- Pair of Polk SDA 2B speakers
«13
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Nightfall
    Nightfall Posts: 10,073
    You're also going to need a source and cables. Do you have the interconnect cable for the SDA's? Do you already have CD's or what are you going to play on them?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Roemer
    Roemer Posts: 44
    I ordered an interconnect cable for them off eBay yesterday. As far as use, I'm hoping to use them as my home theatre speakers (TV, movies, music, etc.) and add on them in the future. Is this practical?
    From what I understand, the source would be the receiver. Is that correct?
    My current setup:
  • Nightfall
    edited January 2017
    Where are you going to get the music? CD's? Records? Files? Streaming? SACD?
    Are you certain you got the correct interconnect? Are those pin/blade or blade/blade?
    afterburnt wrote: »
  • Roemer
    Roemer Posts: 44
    This is the cable I ordered.
    My current setup:
  • Nightfall
    That's a blade/blade cable, what about the back of the speakers? Do you have a picture of the back of the speakers, just a little lower than the one you already posted showing the speaker and IC terminals?
    afterburnt wrote: »
  • Roemer
    Roemer Posts: 44
    Music will be mostly from streaming. But I have a ton of cds in storage I'd like to hear again. And I'm not opposed to also getting a record player in the future. I'm 30, making these speakers about as old as I am.
    My current setup:
  • Roemer
    Roemer Posts: 44
    95% sure I ordered the correct cable
    My current setup:
  • Roemer
    Roemer Posts: 44
    edited January 2017
    My current setup:
  • Nightfall
    edited January 2017
    Also, it looks like the sides are splitting away. Press in and hold the passive radiator (the bigger one on the bottom) with your fingers and watch the smaller 6.5" drivers move out. While continuing to hold the passive radiator in how long does it take the smaller drivers to go back to their original position? Do this on both speakers.
    afterburnt wrote: »
  • Nightfall
    Roemer wrote: »
    Looks like you did, just making sure.
    afterburnt wrote: »
  • Roemer
    Roemer Posts: 44
    I'm at work right now. Just happened to take these pics the other day. I'll check them when I get home. How long should it take? And what are you seeing?
    My current setup:
  • Nightfall
    The very first picture you posted, both sides on the top look like they're separating from the speaker. The passive radiator press test will check if they're still air tight. They should take 3-5 seconds or so to return to normal after pressing, if they go back down right away the cabinets aren't air tight anymore.
    afterburnt wrote: »
  • Roemer
    Roemer Posts: 44
    Ugh, now you have me concerned. I'll be checking that as soon as I get home at 7. Hope everything checks out. Im excited to hear these and it'll suck if they're not good!
    My current setup:
  • Roemer
    Roemer Posts: 44
    edited January 2017
    My current setup:
    tonyb Posts: 32,908
    Roemer wrote: »
    Eh, older speakers just take some maintenance to keep them rockin'. Your in the right place for that, the guys will help you keep those puppys up to snuff. Good speakers, you'll enjoy them.
  • RandyCroissant
    Prior to choosing a Reciever it would be important to know which SDAs you have. They could be 2As or early 2Bs both sound and look very similar however one version is electrically different from the other. To know for sure we would need a picture of the crossover. It is located behind the large passive radiator, carefully remove all the screws and then gently remove the PR. Once the PR is out you may find the white polyfil has fallen that would need to be pushed back up above the crossovers. A look at the crossover will help.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Roemer
    Roemer Posts: 44
    Nightfall wrote: »
    They both appeared to pass this test. Took 3 or 4 seconds to return to their normal position.
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    Nightfall wrote: »
    I see what you're talking about in regards to the seperating... the side felt is coming unglued.
    My current setup:
  • Roemer
    Roemer Posts: 44
    My current setup:
  • RandyCroissant
    Ok great you have SDA 2Bs early version. They are a little easier to drive than 2As and offer you some less expensive upgrade options as well. If you choose that is, others will chime in.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Roemer
    Roemer Posts: 44
    My current setup:
  • Roemer
    Roemer Posts: 44
    Roemer wrote: »
    Nightfall wrote: »
    My current setup:
  • RandyCroissant
    Try to save the gaskets, as long as they are not torn you can re use them. As for a reciever I like Yamaha Aventage series or Pioneer Elite on this forum they are refered as AVRs or audio video receivers.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • RandyCroissant
    Hey just checking did you make any decisions
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
