SDA for your turntable
  • Dennis Gardner
    Fosgate strikes again. He has been on the edge with his processing skills. I wonder if he ever SDA'd in the past?
  • pongshi
    pongshi Posts: 376
    Thanks Jesse. I am a vinyl guy and this looks pretty cool. It is very difficult to send up a cartridge perfectly and this looks like it can help. I found this demo link:
    https://www.youtube.com/watch?v=3kr_x26E5eE
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
    Toolfan66 Posts: 16,929
    I might have to try one...
  • erniejade
    erniejade Posts: 6,315
    Priced reasonably. Interesting
  • Dawgfish
    Dawgfish Posts: 2,554
    Been looking at that for a while. Was wandering if it might be like running SDAs with Sonic Holigraphy; ie not a good match. Would love to find out though.
    nooshinjohn Posts: 25,104
    edited January 2017
    I think it would pair up well actually. The crosstalk this device works with is at the source, while SDA deals with what arrives at the listeners ears after the signal is set free into the room. The Foz is not trying to correct the signal at the speaker like SDA and SonicHolography do.
  • Irrenhaus
    Irrenhaus Posts: 1,082
    Nice.
    Anyone know's the name of the song?
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Ricardo
    Ricardo Posts: 10,636
    And don't tell me that you heard a difference.....
    Cool concept though.
    SOPA
  • K_M
    K_M Posts: 1,627
    That was a noisy record!
  • halo
    halo Posts: 5,616
    We saw / heard this in the Jolida room at AXPONA last April. My wife noticed a slight difference between it being in the signal path vs not.
    halo wrote: »
    That's closer than the rest of us, were your impressions favorable?
  • halo
    halo Posts: 5,616
    I didn't notice a difference. That said, my wife's ears are better than mine and she's not into audio (she is a musician). We didn't have a vinyl setup at that time so we didn't have a dog in the race.
    The way he explained what it attempts to do made sense at the time.
  • thsmith
    thsmith Posts: 6,082
    Is this a problem for TT? I have never heard cross talk in mine.
  • StevieB
    StevieB Posts: 256
    edited January 2017
    Irrenhaus wrote: »
    Nice.
    Cheers
    Soundhound sez 'Here but I'm gone' by Vanessa Fernandez.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • Irrenhaus
    StevieB wrote: »
    Irrenhaus wrote: »
    Nice.
    Cheers
    Thanks.
  • nspindel
    nspindel Posts: 5,343
    I'm wondering.... If this approach is similar to what SDA is doing, then maybe this explains why vinyl sounds so damn good on SDAs?
  • JuanR
    JuanR Posts: 718
    This seems to function as a balance pot, while it will provide some improvement (balance correction) to some turntables that do not have the capability to adjust the arm for azimuth, it does not correct the root cause.
    I have a couple turntables this unit can probably help....
    Has anyone purchased it?
  • vcwatkins
    vcwatkins Posts: 1,993
    Has anyone tried one of these gizmos?
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • muncybob
    muncybob Posts: 2,973
    It's 100% guaranteed?....hmmmm
    Yep, my name really is Bob.
  • K_M
    K_M Posts: 1,627
    thsmith wrote: »
    Play one of those old Beatles records, where all the sound is one just one channel, such as a vocal, and then turn balance to other channel. You will hear the sound that should be on just the other channel but at a reduced level.
    On the CD version, it is completely isolated.
  • bikerboy
    bikerboy Posts: 1,207
    Jesse I thought you are allergic to vinyl?
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
    F1nut Posts: 49,808
    Ah-choo
    bikerboy wrote: »
    He is allergic to direct sunlight exposure as well...
    pitdogg2 Posts: 24,587
    bikerboy wrote: »
    yes but is he self sealing after the fact?
