Well Crap!
Totally out of the blue, I saw the Adorama deal and had a buyer for my current lsi setup in the same day. So I went for it but now I'm seeing the 703's are not wall mountable. While on the phone with Polk, they told me they were. What sort of solution should I look at to get them on the walls? Any sort of conversion hanging system or shelf that works well with these? Thanks for any input and if you have pics, that would be great too.
Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
You get the 707/706c/703 bundle? You could just spend the extra $500 if you can and get the 7 speaker bundle with the 702fx which are wall mountable. Either keep the whole bundle if you have space/$ or flip the 703s, I'm sure you could at least recoup your $500 or more. The 703 are pretty big and you'd probably have to build your own custom shelf. They are about 30 lbs too.
Those speakers should really be set on stands.
About the only thing I can think of for wall mounting is this:
https://www.amazon.com/Peerless-Adjustable-Component-Shelf-AV/dp/B00155PSXS/ref=sr_1_27?ie=UTF8&qid=1484198163&sr=8-27&keywords=peerless+mount
I bought the full package with the fx. Don't really have room for stands with my setup.Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
I use the B-Tech BT77 for my bookshelf speakers.
https://www.amazon.com/B-Tech-BT77-Ultragrip-Speaker-Black/dp/B004DCAOHK
From the start they have supported RTi4, LSi7, and RTiA3.
Adjustable clamps will accommodate the 703, and rated to hold up to 25Kg
kilogram, cuz the BTech comes from the UK.
Simple conversion 25kg = 55 lbs. Will easily hold the 703 when the mount is properly installed on the wall via a stud or anchor
Erik Tracy wrote: »I use the B-Tech BT77 for my bookshelf speakers.
Nice speaker mounts.
Other option would be to make a shelf.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
703's are certainly wall-mountable. This is using the "OmniMount ECSB Component Shelf Wall Shelf for TVs and Video Accessories"x2, available from Amazon.
These have been solid, despite being within 100 miles (160 km) of two 5+ earthquakes.
Also placed the speakers on "Auralex Acoustics MoPAD Monitor Acoustic Isolation Pads", on the mounts. -
The nice thing about the b-tech mounts is that they can swivel and be tilted for more flexibility in speaker position and angle to the listening spot.
703's are certainly wall-mountable. This is using the "OmniMount ECSB Component Shelf Wall Shelf for TVs and Video Accessories", available from Amazon.
Nice setup, run them wire in the wall.
just because there is no mount on the speakers doesn't mead you can't wall mount them.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
This was going to be my suggestion as well. I have considered using them in the past.
BUT I would NOT suggest using anchors with the 703s. I would definitely find a stud. If the studs are not in the ideal location, you could get a 2x4, cut it down, paint it to match the wall, attach the 2x4 to the studs, and then the mount to the 2x4. not quite as clean looking, and might not pass the WAF, but in my house speakers mounted on the wall don't pass the WAF, so I can't help you there...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Caveats/Notes -
- The reviews on Amazon suggest that the B-Techs need to be periodically tightened, and that you should also drill holes in your speakers.
- The OmniMounts swivel side-to-side if needed, and Auralex Acoustics MoPADs provided the tilt I needed.
Both are certainly options.
Caveats/Notes -
There are other methods for securing the speakers to the mounts.
Instead of drilling holes in my speakers, I used friction tape on the side clamps, and a band of zip ties around the speaker to secure them to the mount.
I've checked the tightness of the screws periodically, but have never noticed any loosening.
This has proven to be a thumbs up mount in shaky SoCal.
I can give a hearty two thumbs up for the B-Techs, I use them for my rear surrounds. They have been used with bookies that are at least 25lbs. Now, I do not have them tilted much, but I've never had to re-tighten them or drill holes for screws. My wife even nailed her head on one once. Her head lost & the speaker didn't budge.
Thank you for all the input. All of you have been a great help and have eased my mind. I think those b techs are the way to go and Amazon also suggested blue tack to go with them.Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
The BluTack is a good idea & would work well.
Erik Tracy wrote: »kilogram, cuz the BTech comes from the UK.
I think he might have just been joking since we (USA) don't use the metric system. He's a teacher, surely he knows what a kilogram is.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Former engineer here - we take everything literally...force of habit to avoid assumptions.
I use them, too, for RTi4s. -
