new setup for chevy nova
Hi, I just made ordered a alpine 164bt, alpine ktp-499a, polk db651 6.5 for the front and polk db691 6x9 for the rear. I was going to just power speakers off head unit but every post i read says install a amp. I just didnt want to run the wiring until after i get a sub in about 6 months+. I went with the ktd but couldnt find any threads using this setup. I was wondering what your thoughts are on this setup? I was told by crutchfield that the alpine ktp-499a is a true 45x4 rms 180 watts. Is 45watts enough for the db651 and db691
This will be going in a 76 nova ss. with a custom built center console. the console with have the 6.5" mounted in it and the cd player. The 6x9 will be in the rear deck.
  • NovaSS
    setting cross over with no sub. I have no bass right now the 6.5 are at 100hz 24 slope 6x9 80hz 24 slope and i want more bass their is none right now
  • skrol
    skrol Posts: 3,340
    edited December 2016
    Love to see pics
    The head unit should drive the db651 but a good external amp will do better.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • codycatalist
    skrol wrote: »
    Love to see pics
    He is right, it will work fine without but would always be better with an external amp. If you want what you can do is get an amp for the speakers and run the power and ground through a distribution block. This will split the ground and power wire from one wire into two or more so if you want to add another amp for the sub later it is already basically wired for you.
    At least that's what I would do because if you don't upgrade now...you will in the future.
    I loved my DB speakers and they sounded great with a class A/B amp and just off the head unit.
  • Gatecrasher
    Gatecrasher Posts: 1,550
    Good to see another Nova man on the forum!
  • ken brydson
    ken brydson Posts: 8,650
    You saw, he went. Hasn't been back in 4 months....
  • Gatecrasher
    Darn I thought he really meant "No Va" which means "doesn't go" en Espanol.
    No voy a ir a ninguna parte sin embargo. Polk hombre para toda la vida!
  • skrol
    skrol Posts: 3,340
    Yeah, I heard that was an issue selling the car in Mexico, though some say it was not true.
    Stan
    Main 2ch:
    HT:
    Other stuff:
