Sometimes Big Scores Come Cheap in Small Packages!
I doubt that anybody else on the Forum cares a hoot about this little item I picked up off eBay the other day, but it is a bit of dream come true for me.
I'm a real fan of vintage, as well as current, Perreaux electronics. I have two of their mid-1980s amps, a PMF 3150 and a PMF 2350, a couple of preamps, and a tuner. (I also have current models of Perreaux's top-of-the line preamp and monoblocks.)
Perreaux equipment is, as the saying goes, "built like a tank." However, the 1980s amps have two weak spots, neither of which is a fatal flaw -- 1) the blue "on" indicator light tends to fail after about 20 years as does 2) the on/off switch, which is the same in each of the amps.
The larger amp, the PMF 3150, has had failures of both. A technician did the "work around" for me a few years ago: He substituted an LED for the failed blue diode, and he hard-wired the on/off switch in the "on" position so that I could put a single throw/three pole motor control switch in the power cord to turn the amp on and off.
The motor control switch works fine, but it irritates my aesthetic sense. I have yearned for a replacement switch, but never expected to find one because they have been out of production and out of stock for years.
But look what appeared on eBay a few days ago:
A "new/old stock OEM switch! :)
Even at $34.95 I consider it bargain to restore my old PMF 3150 closer to its original operating condition!
    txcoastal1 Posts: 13,134
    Those amps are some serious iron. Have you replaced any of the caps or the thermistors?
  • oldrocker
    oldrocker Posts: 2,590
  • Moose68Bash
    Moose68Bash Posts: 3,842
    txcoastal1 wrote: »
    I've had both amps tested a couple of times over the past decade. The PMF 3150 has always tested "as new." The PMF 2350 had all new caps two years ago because there was a slight hum that needed to be addressed. Otherwise, it has always tested "as new."
  • Moose68Bash
    oldrocker wrote: »
    Congrats M...
    Thanks!
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I figure you were supposed to have those.
    Nice pickup! :)
    msg Posts: 9,486
    Man, that's a good feeling, isn't it? Finally being able to restore an old favorite to OE spec, getting it working as intended? That's just the sort of thing I'd enjoy doing as well, and would catch myself repeatedly admiring the work afterward.
    Congrats on the find.
  • Moose68Bash
    msg wrote: »
    Thank you. We all need some pure luck from time to time.
    F1nut Posts: 49,840
    Gotta luv it!
  • soundfreak1
    Moose68bash, how old are you? And how do I get in your will?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Moose68Bash
    @soundfreak1,
    I'm 70, which is in all likelihood irrelevant because my wife is 10 years my younger. Besides, my daughters have first dibs! :)
  • soundfreak1
    Rats! LOL.you got me on to Perreaux and I appreciate it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Moose68Bash
    @soundfreak1,
    I just wish more folks in the US would try Perreaux products, vintage or new, because they don't know what they're missing -- fine performance and good value.
