Recommended room sizes for various SDA speakers
machone
Hey guys.
Does anybody have a list that correlates SDA speakers with recommended room sizes?
For instance a SDA SRS needs a large room. How large?
What about a SDA SRS2? Where does it best fit?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
And how about the SRS 3.1TLs that I am awaiting?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
I have my SDASRS 2's in a room about 20' X 22' X 9' that I can close off. Sounds great.
Hey guys.
All good points. I wish my room was of a better dimension , but like so many others here, we are stuck with what we have,lol. I don't play the SRS2's super loud , I've got to preserve what hearing I have left.
I have my 2.3tl's in a 15x29x8' room and they sound great to me.I would like to hear another pair of SDA speakers to compare them to though since I have never heard any others besides my own.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre -
Anytime Sunday? I can bring the McCormack if you want.2 Channel
Oppo 103
Pangea PC
My living room is 18' x 15' and the 2Bs do fit but are not getting the air of 3 feet of open space on the outer sides. Hey we all don't have great rooms w/ the optimum space. Do what you can and the spread should really not be closer than 6/7' w/ the fore mentioned open areas. Most have seen this before but for an example here's mine
My 2.3tl's are in a ~ 20' W x 18' D, open to kitchen on the 18' side. Vaulted ceiling with multiple angles. Sounds very good.
"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
My room is a garage converted to a playroom that is 18.5 wide by 21 deep x 9.5 tall. It does have some obstacles such as the slot car racetrack and some racks in the back of the room in front the garage door.
I have fully modified SDA 1As that fill the room but.....
I have been looking around the internet at several Polk SDA models just to see what is out there. If I found something interesting I might consider upgrading. It would be my nice to choose a model that could be TL'ed but not necessary. Power is not a problem as my Hafler will drive any of the Polk models.
SDA 1s, 2s and 3.1s would side right in and replace the 1As.
SRS models would require remodeling and rearranging but not that big a deal.
I have found the following speakers and asking prices in the South East:
SDA 1C studio for $450
SDA 2A for $225
SDA 2B for $359
SRS 2 for $800 (don't know if blade/blade or pin/blade)
SRS 2 pin/blade for $700
SRS 2.3TL for $1350 (seems really high?)
There are several of the large SRS models out there for around $2500 but I believe they would be overkill in this room. Besides I don't want to spend $2500 and then upgrade these beasts.
I would like to keep it below $1000.
My question is if you had my room and wanted to upgrade today from the 1As what would you pick from this list.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Not necessarily - depends on if it has been modded."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
How much of an upgrade could one expect moving from SDA-1As to SRS 2s?
Is $700-$800 for a set of virgins in great shape an OK deal?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Drumminman, you have 1 beautiful living room. It's to bad those monoliths take away from your built ins and fireplace. The wife had to have said something about that arrangement..lol Those darn SDAs and their placement quirks.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
How much of an upgrade could one expect moving from SDA-1As to SRS 2s?Is $700-$800 for a set of virgins in great shape an OK deal?
I paid $600 for SRS 2 pin/blade speakers about a month ago. Another set on eBay had a single bidder, and sold for $300 including original boxes and packing materials. The SRS models--any of them--are somewhat scarce. I waited years for a pair to show up for sale not where I live, but where I could reasonably travel to--and even so it was a thousand-mile round-trip from my Father's home in California which itself is 4000 miles round-trip from home.Post edited by Schurkey on -
Thanks schurkeyMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
