Interconnect cable
Flathead38
I am getting ready to put together my interconnect cable on my SDA 1's. I have my cable and Neutrik Speakon connectors ready. I have noticed in the "Handbook" that pin 1 different on the left and right speakers. What should I be watching out for as I wire these up? My speaker connection is two pins with a hole below them.
As long as you wire your cable straight through i.e. + to + and - to - you should be fine. The important part is especially if your SDA 1's are blade/blade or the original 3 pin connector is the wire that go's to pin 1 (it will be a different color depending on which speaker left or right), I would connect which ever color wire go's to pin 1 to the + pin on the Neutrik Speakon connector that your putting in your speaker.
Hope this helps and makes sense.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Thanks, that does make sense!
I appreciate your help.
