Headphone Amp Suggestions
gudnoyez
gudnoyez Posts: 8,068
edited February 2014 in Headphones
I was wondering if anyone has any suggestions for a headphone amp. I should be getting my HD 598's tomorrow I will mostly use them with my Oppo 105, or one of my Marantz' s so I should be covered there, just wondering what would e a good standalone amp so I can use my headphones on the computer or IPhone or IPod? Budget lets say $150-$250. Any suggestions would be appreciated.
Post edited by gudnoyez on
    EndersShadow Posts: 17,536
    Well the computer I would recommend the Audioquest Dragonfly v1.0 (AudioAdvisor for 99). For your iPhone or iPod I would suggest something cheaper like a JDSLabs CMoy.
    Both pieces together should be around 150 give or take.
    But I would suggest looking at 2 different pieces, one for your computer and one for your portable devices. Best way to approach it IMHO.
    Thanks I saw that Dragon fly on Amazon how does it work, it looks like a stick you plug into the usb port.
    gudnoyez wrote: »
    Yup that's basically it. You set it as the default audio device and away you go.
