Another "help me choose an amp" thread :(
JimAckley
JimAckley Posts: 1,138
edited June 2013 in Electronics
So I hopped on my local craigslist, and have been looking around at amps. So far I found an Emotiva XPA-2, a Sunfire Cinema Grand 5-channel, Rotel RMB-1075, and NAD C272. I'm presently in a 2-ch setup with an SC-37, but plan on expanding (again) in the future, so both 2-ch and 5-ch are valid choices, per se. Just wanted y'alls thoughts on the various amp companies.
- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
Post edited by JimAckley on
  • Conradicles
    Conradicles Posts: 6,071
    edited January 2013
    I had the NAD C272 and it is fantastic. Tons of power and a sweet smooth sound. It would be a nice match to speakers that are not so "laid back".
    tonyb Posts: 32,945
    edited January 2013
    For me anyway, I look for musicality in an amp. Of those choices, the Nad is the more musical of the bunch.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2013
    I love my Sunfire, that's what I would go for out of that bunch.
  • JimAckley
    edited January 2013
    Can you guys give me an idea of the "sound" of the amps you've used? e.g. warm, cold, bright, etc.
    - Computer Rig -
    - Main Rig -
  • marvda1
    marvda1 Posts: 4,896
    edited January 2013
    jim, new? used? what's your budget?
    Puritan PSM156
  • headrott
    headrott Posts: 5,496
    edited January 2013
    The more recent amps I have used being: Aragon 8008bb, Pass Labs Aleph 30, and BAT VK-200
    1) Aragon 8008bb- Sounds relatively cold yet relatively bright sounding but detail is outstanding. This is the most detailed amp out of these 3 (but only barely more than the VK-200). Moderate soundstage width with good imaging.
    2) Pass Labs Aleph 30- Sounds relatively warm, but not as warm as the VK-200. The detail is very good and has a wider soundstage than the Aragon. The imaging is also better than the Aragon. If you do not have efficient speakers and/or you listen at 100+dB's this amp won't cut it for you though.
    3) Balanced Audio Technology VK-200- This IMO is the best of the 3 amps. It is very warm sounding and yet highly detailed (not as high as the Aragon though). The soundstage is huge and the imaging is highly 3D sounding!
    Hope this helps Jim.
    Edit: After seeing your reply below Jim, all these above amps won't do for you (they are all $750+)
  • JimAckley
    edited January 2013
    Marv, great to hear from ya! It's been too long. These are all used on CL. I'm trying to keep it near $500. These are all pretty close, give or take a buck or two.
    - Computer Rig -
    - Main Rig -
  • JimAckley
    edited January 2013
    DSkip wrote: »
    Tube integrated...
    or buy all these:
    http://dallas.craigslist.org/ndf/ele/3577070257.html
    Don't wanna do a tube intergrated since this will be expanding to a home theater setup
    - Computer Rig -
    - Main Rig -
    edited January 2013
    NAD, Parasound, B&K are all "warmish" SS amps. There are more. Take a listen and find one in your price and power range. Don't think you can go wrong with any of those.
    BAT or Pass ALeph for $500? Not going to happen! Think BUDGET!
    cnh
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited February 2013
    Post 12 reported.
  • leroyjr1
    leroyjr1 Posts: 8,785
    What kind of speakers are you running?
  • Aragon8008
    Aragon8008 Posts: 10
    edited June 2013
  • Aragon8008
    edited June 2013
    Wyred 4 Sound also has great value amps and integrated.
    tonyb Posts: 32,945
    edited June 2013
    Aragon8008 wrote: »
    Not for 500 bucks they don't. :smile:
  • lanchile
    lanchile Posts: 560
    edited June 2013
    Well, I wish it was that easy... The best amp for me can sound the worse for you! and that is the same in speakers!!! I remember a friend of mine that build a "Gainclone" amplifier and to him it sounded really good...but for my taste it sounded so "dead" (no bass, the midrange was not defined, and the treble was very "fatiguing") But He liked it!!! So We all have different taste! (Thanks god for that lol)
    Make it simple...Make it better!
    EndersShadow Posts: 17,579
    edited June 2013
    dead thread bumping lol. Before Aragon's post the last post was in February of this year
