A slightly different take on the Dreadnought
F1nut
F1nut Posts: 49,840
edited December 2013 in Vintage Speakers
For many years I wanted to upgrade the AI-1 SDA cable on my stock AI-1, but I wanted to keep the original pin/blade type terminal and socket because I never liked the idea of using binding posts for the connections. I don't know exactly why, I just didn't. I looked and looked for something that would work, but never did find anything. Along came the Dreadnought. I liked the idea of using a better isolation transformer, but still didn't want to use binding posts, so I did nothing. Then at one point another Polkie and I were looking at having new pin/blade terminals made, but that never panned out. When the 1000V Avel deal came up I knew it was time to abandon my hope of finding a pin/blade type terminal and look for something else. I found the Neutrik Speakon connectors and decided that is what I would use.
Since I use the excellent MIT Shotgun S1 cables I wanted to use the same for my new SDA cable. I talked with the good folks at MIT about this and they didn't think their cables with the network boxes would be a good idea as those boxes are directional. They suggested using the Shotgun cable without the boxes, so I acquired 16 feet. They warned me that this cable was a pain to terminate and they were right. The guts are not simply your typical stranded wire and that's probably all I should say about that. I have to thank the good folks at MIT for making this possible, thank you!
So, with the cable decided on I made very careful measurements to find out which of Neutrik connectors would work. I found that the NLT4MP-BAG female chassis socket would just fit between the upper Cardas binding posts on my 2.3TL's in place of the stock pin/blade socket. I chose the NLT4FX-BAG for the male end. As the MIT cable measures 21mm in diameter and the maximum inside diameter at the tail end of the NLT4FX-BAG shell is only 16mm I had to remove the rubber bushing, the metal ring that holds it in place and the plastic locking device inside the shell. That still wasn't enough, so I had to use my Dremel to enlarge the end of the shell. Let me tell you that was a lot of work. Things went very smoothly after that and the cables were done.
Needing an enclosure for the transformer I looked around and found something I liked from a company in China, but their stock sizes weren't what I wanted or needed, so I asked about custom sizes to which they said sure. After sending them my drawings they got back to me saying sure, no problem, but we have a minimum order of 10 for custom work. Since I didn't need 10 I dropped that idea and looked elsewhere. I talked with a certain someone (THANK YOU!) that was willing to make me a one off and placed the order.
The work on the binding post plate to accommodate the Neutrik chassis socket was a bit tricky because it's a one shot deal, but all went smoothly and installing the Avel in the enclosure was straight forward. I'm leaving out some of the finer details in this project, but I would suggest that one should have a certain level of knowledge, the right tools and the skill set required before tackling such a project. If anyone has specific questions, I would be glad to help.
I would like to thank all those that have gone before me on similar projects. You shared your knowledge, experiences and gave me ideas to work with. You guys make this forum the best around.
Oh yeah, sounds GREAT!!!
Both cables finished.
Close up of the Neutrik connector.
The Neutrik chassis socket installed. MIT jumpers, of course!
I tried black cap screws first....nah
With stainless steel cap screws.....much better.
The cover lined with Dynamat.
The guts. Stainless steel hardware was used to attach the transformer.
Behind the antique table I use for my gear.
Damn, she's pretty.
Post edited by F1nut on
«13
  • headrott
    headrott Posts: 5,484
    edited January 2013
    Looks fantastic Jesse! What do you think of the sound of the Dreadnought itself? That is imaging, soundstage, detail, etc? Thanks for sharing this.
  • george daniel
    george daniel Posts: 12,096
    edited January 2013
    well someone just raised the bar! Atta'boy Jesse.
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    Very nicely done.
    I'll be doing something similar but with a different MIT cable that works with what I'm currently running. Unfortunately I have to use binding posts on the case. I'm not to particular for that though.
    Nice jumpers too.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2013
    A beautiful job, Jesse! Nicely done!
  • brgman
    brgman Posts: 2,859
    edited January 2013
    That's great looking stuff man.
    The shotgun cable had to be a bear to work with.
    what are the jumpers made from?
    I’M OFFENDED!!!!
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    Excellent ! Nice work Jesse.
    EndersShadow Posts: 17,543
    edited January 2013
    brgman wrote: »
    Those are Shotgun jumpers. They do make jumpers for their stuff you just have to call and custom order them. With that said they only make jumpers for their higher end speaker cables, no no jumpers for any EXp folks :sad:
    Toolfan66 Posts: 16,946
    edited January 2013
    Nice!!! I am so making these changes!!!
    Great job Jesse!!
  • nspindel
    nspindel Posts: 5,343
    edited January 2013
    Outstanding! Welcome to Club Dreadnaught!
  • strider
    strider Posts: 2,568
    edited January 2013
    M'eh, it's ok.
    Just kidding, good work as always my friend!
    Wristwatch--->Crisco
  • drumminman
    drumminman Posts: 3,396
    edited January 2013
    Nice work Jesse.
    I'm curious though, what don't you like about using spades for the AI-1 cable?
  • tophatjohnny
    tophatjohnny Posts: 4,167
    edited January 2013
    Beautiful work. We are lucky to have a genius among us! Can only imagine the crazy sounds coming from any of your systems!!
  • ZLTFUL
    ZLTFUL Posts: 5,640
    edited January 2013
    I really hate you SDA guys...makin' me want a pair of my own so I can create beautiful Toroidal artwork too... :mrgreen:
  • Face
    Face Posts: 14,340
    edited January 2013
    Nice job Jesse!
    edited January 2013
    Oh yeah BTW nice looking case!! Who made that for you?? LOL!!:cheesygrin:
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    edited January 2013
    Looks great Jesse!!! Top notch. Looks like McLaren made it.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    F1nut Posts: 49,840
    edited January 2013
    headrott wrote: »
    Thanks Greg.
    Yes, it is all there better than before.
    MIT's, of course.
    Spades always come loose, always. The only reason I'm using spades on the jumpers is because my speaker cables use bananas. Every once in a while I check the spades and sure enough, one or two will be loose and believe me, I torque the hell out of 'em.
    Yeah, I wasn't sure you wanted me to say. Folks, Larry made the case and the faceplates.
    LOL.....Yep, Larry McLaren. :wink:
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited January 2013
    Excellent work Jesse, as usual.
    You might want to look into AudioQuest spades. Mine have never became loose, even with very heavy speaker cables pulling on them. I always have to use a wrench to loosen the Cardas posts when I want to remove them. If this is something you want to pursue, AQ is good about making product recommendations for specific applications.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited January 2013
    Very nice F1! I have heard that Dreadnoughts improve the sound of SDAs over using stock or aftermarket SDA cables even when using common ground amps where a Dreadnought is not needed. Is this correct and if so what kind of improvements did you notice? I've been debating for some time on trying one with my SDAs using common ground amps.
  • drumminman
    edited January 2013
    I built an 800VA Dreadnought and used it with a common ground amp. After a period of burn in (maybe 25-50 hours) the improvement was easily audible: music seemed to float in the air instead of coming from the speakers. More like live performers in the room. Instruments were clearer especially in complex passages, better transients, more tactile bass.
    Do it - I'm betting you'll love it. Avel Lindberg sells the 800VA transformer off the shelf too.
    If you search the forum you'll find some great "how to" posts.
  • nspindel
    edited January 2013
    The Dreadnaught definitely produces an improvement over a straight SDA connection when used with a common ground amp.
  • DarqueKnight
    edited January 2013
    drumminman wrote: »
    nspindel wrote: »
    This is all in your mind...placebo effects.
  • nspindel
    edited January 2013
    Just like cables.
  • headrott
    edited January 2013
    Well, at least the Dreadnought "looks good" though.:rolleyes::razz::smile:
  • vcwatkins
    vcwatkins Posts: 1,993
    edited January 2013
    Outstanding F1.
    I've got my Dreadnought built (thanks Neil & Larry), but I'm mulling how to terminate at the speaker (currently updating CRS+'s). Will probably just default to Cardas spade. Wondering if I should, or even could, start breaking the DN in before speaks are done? It's KILLING me seeing the DN just sitting there.
    Craig
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • Moose68Bash
    Moose68Bash Posts: 3,842
    edited January 2013
    Great write-up and beautiful work, F1nut!
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited January 2013
    Thanks for the great write-up. As usual Jesse, you have managed to raise the mark for the rest of us. Outstanding work! It's a shame it's hidden!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    edited January 2013
    Thought I would post this pic here as well. My case is done except the transformer. It's on it's way!!
    Thanks Jesse!!:biggrin:
    SCompRacer Posts: 8,353
    edited January 2013
    High marks Jesse! Love the Neutrik connectors. They got everything covered.
  • GlennDog
    GlennDog Posts: 3,093
    edited January 2013
    Toolfan66 wrote: »
    just to be clear . . you've got a 1KVA tranny on its way? . . . . . cuz I've got a spare, thoughts?
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
