Why do the new head units look so bad?
eloplayspolo
So I have the stock deck in my subi right now and its fine, but I would like to get a sound quality piece.
Going thru all the current head units and they all look like trash!
I may have to fork over the dough for a double din.....
Anyone have any suggestions?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
Headunits have been getting pretty flashy for a while now. I just keep using the older gear.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
The new Pio P80 is a good hu for around $300-350. It's basically a relaunch of the older 800/880 series.
I agree, headunits today remind me of crappy mini-systems. All funky plastic and obnoxious lights. Seems the notion of putting a new stereo in a car and having it look like it belongs there is lost. One of the reasons I've not really looked for a replacement for my ancient Sony ES headunit.
I have seen people replace the LEDs in a HU to get it to match the lighting in their car. That might be something to consider if you're good at soldering. Will make it look slightly less obnoxious.
Monster AVL-300, HTS-2500 MKII -
Any features in particular you're looking for? Most additions these days can be done through the stock system which I prefer as it keeps the stock look.
The only things I would install is a double-din touch screen as it looks very clean with no big buttons or flashy lights.
there are plenty of nice double dins that look classy. I have a nice car with black leather and a class interior, i dont need a ton of lit up plastic. That pioneer is alright..... some of the sony and jvc units look nicer than a lot.
I might go back to the same style kenwood i had before.2013 Toyota Prius
Mosconi 6to8 v8 -
obtaining a level signal from the stock unit is annoying. I have an MS8, but even then... Maybe ill try and find an older eclipse unit with good 7v preouts.2013 Toyota Prius
Mosconi 6to8 v8
