How much Epoxy (JBWeld) needed for a pair of speakers?
Mystery
Planning on getting some cheap epoxy from HFT and would like to know how many pair of speakers 1oz epoxy can serve.
There are different sizes from .34 oz, 1 oz to 3 oz etc.:rolleyes:
I have 3 pairs (4, 5B and 7) to apply epoxy.
I just want to apply them on 4 places, not all around the magnet.
Thanks for suggestions.
Post edited by Mystery on
IIRC....I did all eight 6.5" MWs from my SRS2s with just one package (2 tubes) of JB weld, and that was full circumnavigations ! Arrrgggg! Do yourself a favor, go to a Michaels or other arts & crafts store and buy one of these:
Don't wear a good shirt, and have fun !!!!:cheesygrin: -
Thanks for reply gdb. So 1oz should be good enough for me.
Funny you mention that thingy. I went to a garage sale just last week and didn't want to come empty handed so picked up one of those for 50 cents.
BTW, what do you call that thing? It's not a putty knife.
+1 To gdb^^^ on the tool!
I did 10 drivers with one "JB weld tube set", 4 places on both sides of the magnet. I believe that package was 2, 1oz tubes.
May I suggest that the application tool that you buy is not metal (ferrous material). I purchased a metal spatula, and upon the fist application learned that a plastic (non ferrous) material would have been less problematic. I was not a cool as I thought I was!:redface: -
Mine is carbon steel, it's commonly referred to as a troll's tool.....JK ! it's called a palette knife.
Buy the loctite epoxy stick
quick easy and not as messy
roll it in your fingers like a big booger to mix the 2 parts and stick it on.
hardens in 2 minutesMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I had problems with that adhering to the magnet and metalwork. It seemed to not stick to it very well. The JB weld is messy, but worked like a dream. Just say'n,,,,Buy the loctite epoxy stick
hardens in 2 minutes -
I'm gonna try real boogers !:razz:
less is better
Thanks for replies.
Now few concerns.
I read other threads on applying epoxy and got confused.Are you putting it all around the magnet?? If so there is no need to do so, four places around the top and bottom of the magnet.. Your 5jrs may need it around the basket and magnet as well, some of the older Polk drivers magnets are not rivited to the basket.. You can take a flashlight and shine it in the spider area to see if they are or not..
So where exactly do I apply the epoxy? Around the magnet or on the basket?
How do I check whether the driver has rivets or not?If I'm reading the first sentence correctly.....where the front plate of the magnet attaches to the basket is not necessarily where the concern should be, obviously since these are riveted (like Larry said, some aren't). It's the joints in between the magnet, the front plate, and the back plate where things 'let go'. I am just using a thin bead of JBW around both those seams, smoothed with my fingertip, and cleaned from the magnet with Goof-Off (this is cosmetically motivated:rolleyes:)...
G~
So epoxy the seams around the magnet? :question:
A picture of before/after JB Weld will really help here.
Instead of the tool gdb used (which looks good by the way) I used round toothpicks just roll it onto a toothpick and roll into the area you need. I did both magnet and basket on my drivers can't hurt.
Thanks for replies.
Now few concerns.
Here you go, from TF66: http://www.polkaudio.com/forums/showthread.php?98202-JB-Welding-your-magnets-on-your-old-drivers&highlight=glue+magnets
When I did mine I wound up putting epoxy around the entire magnet rather than doing 4 sections. Probably overkill. For a spreader I used the then thin end of a wooden shim. It's what I had handy and it worked like a charm. If you're like me you'll want to have plenty of paper towels around to wipe off the excess!
Gloves are good too, the latex or vinyl kind like you see in doctor's offices."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »
That looks little complicated than I thought.
Do you have take everything apart like that? :eek:
I was hoping I could just apply epoxy on the back of the drivers.
NO !!!! Take Nothing apart if the driver is functioning properly. You just want to immobilize everything right where it is ! Frozen up ???? That's a whole 'nother story !
Weird...tried to eliminate the double "it" caused by the site, either 2 or none is all it will allow !!:eek: -
What GDB said! TF66 was only showing ruined drivers to illustrate how they're constructed.
The epoxy is the dark gray stuff that he applied in two places: between the front cover plate and magnet and between the back plate and magnet.
Here are some different pics, see post # 53: http://www.polkaudio.com/forums/showthread.php?97719-SDA-1C-s-are-ready-for-the-upgrade-bug/page2&highlight=weld
More pics here, though he used a different (clear) adhesive than JB Weld. It's a little hard to see: http://www.polkaudio.com/forums/showthread.php?88059-magnetic-shift-insurance&highlight=magnet+shift
Not difficult to do at all."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Weird...tried to eliminate the double "it" caused by the site, either 2 or none is all it will allow !!:eek:drumminman wrote: »What GDB said! TF66 was only showing ruined drivers to illustrate how they're constructed.
Thank you.
Will give it a try this weekend. :loneranger:
Buy paper towels !
Found an AK thread with a picture I like.
http://www.audiokarma.org/forums/showthread.php?t=447617
BTW, is this only for Polk speakers or same goes for others such as Advent, ADS etc???
All my old Advent driver's magnets......would require repeated hammer blows to go anywhere!:eek:
Good to know that my NLA and prodigy tower drivers were made to last.
duplicated....
No epoxy needed on the vents. Foam ??? Whole 'nother story !!
My 1st refoam job was NLA followed by Prodigy.
So far my refoam experience is limited to those two and both came out good.
I'm still procrastinatin' on my Advents, I'm having to much fun listening to Polks for the moment!
So the magnet shift happens to Polk monitor series only or even RTA 8TL's?
Is there a date since Polk upgraded the glue?
Thanks for info.
I would JB weld anything built by Polk before 1995. Original Monitors, SDA's, or RTA's original and later versions like your 8TL's.
Happened to one of my RT15's. :frown:My humble setup...
...is no more. -
goofyGAguy wrote: »Happened to one of my RT15's. :frown:
Thanks all for comments and suggestions.
I finally have few drivers open.
I happened to get a frozen mid of S8 this weekend and was really confused to see everything looks normal.
The magnet is perfect and solid. When I shake the speaker, nothing moves and everything is aligned perfectly.
My assumption as shifted magnets would have something visible like loose magnet, twisted metal or something.
I've attached a pic here with highlighted area for my confusion.
Now, if the magnet is not moving at all in this driver where I'm supposed to apply epoxy, how did this happen to this driver and how epoxy will prevent frozen driver if all epoxy does is makes the outside strong?
Or, is there other things that can freeze driver besides magnet shift?
Also, I see 3 places for epoxy, one on top side of magnet, one on bottom (red highlighted) and the third is between the basket and the magnet cylinder piece (highlighted in blue) but I'm afraid epoxy will sip in the crack if I apply between the basket.
Thanks for clearing my confusion.
The "shift" amounts to one half of the air gap that exists between the voice coil and the silver/pole piece. (not a big distance)
Disclaimer: my experience is limited to the vintage 6.5" MW drivers only. -
I'll just apply epoxy to the magnet and the silver base for peace of mind.
Still not sure how that prevents the magnet from shifting as drivers can freeze with perfect non-moving magnet.
