How do you mount your center channel(above TV). Do you tilt down the speaker?
How do you mount your center channel(above TV). Do you tilt down the speaker? I am using this mount. http://www.buy.com/prod/peerless-pm600-multi-mount-vcr-dvd-wall-mount-kit-45-lb-peerless-pm600/q/loc/111/202070144.html
but right now the speaker is not tilted.
How do you mount yours? Do you tilt it down to your ears level?
Post edited by ahtze on
It would work best if it was pointed towards ear level.
I just have my center channel sitting on top of my TV, but that's not an option for everyone.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I'd like to see how you mounted your center on that bracket. How about a pic?
The best thing to do like said above is to tilt your center so it fires at your ear level. Pointed at the listening area if you will. if that bracket is above or below your display, you can go to Home Depot and get rubber door stops , the old fashion kind. This will give you an angle up or down depending on what you need.
At present time I have my center channel resting on top of my tv. I have a single rubber door stop underneath the leveling foot that come out of the back of my center channels on wall bracket. It for placing on a table. The leveling foot is not long enough to get the angle I need so I positioned the Door stop to achieve the angle. I can snap a pic for you. It might not apply to your situation so I'll wait to see if you wanna see.Dan
I only have about 6"-8" from the top of my center channel to the ceiling. I almost have to point it down at my ears. (It would be way above my head when standing if I didn't.)
It is sitting on a shelf I mounted across the corner above my TV.
There you go. Right now, I put Styrofoam to tilt the angle down.
If the angle is pointing at your listening area Your good. if not the Door stops work excellent.Dan
Check this one out at audio Advisor: SKU OMCCH1
http://www.audioadvisor.com/prodinfo.asp?number=OMCCH1%20%20%20%20BLKTesting
Testing
Testing -
I had this last one but the CS400I is still too heavy to go on top of the TV. I made a little stand and it's now underneath the TV pointed up towards ear level.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
I have my CSiA6 mounted up top of my TV with a mount i made out of a few beer's, some MDMF, screw's and a jigsaw
lol
Oh and it is angled slightly down, maybe like 12*
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
I used to use the same shelf that Ken linked to in Post #7. I had my CSi5 on it. Because it had the lip, I didn't have to worry about it sliding fwd off the shelf. But as you may see in the pic the TV has to have some kind of back sticking out. I have a Rear projection (and its a pretty steep angle like in the pic).
At some point I moved the speaker to the shelf above the TV in my entertainment center (and eventually upgraded to the CSIa6) and had to increase the angle even more.
Whatever you do, that shelf you have is kinda short, so if you tilt any more you risk the speaker sliding forward (and maybe off-even if its shelf length is adjustable). I have a pretty good angle on my CSiA6, so to prevent it from slipping forward, I put two rubber feet under the front of the speaker, giving it a grip essentially which prevents it from sliding.____________________
Pool: Atrium 60's/45's -
bookmarked and b back l8er, bro, :-)
girshircub wrote: »bookmarked and b back l8er, bro, :-)
^^^^Reported____________________
Heres a nice solution for you PJ guys. I have Lovan M2 Center stand/paired with the CSi5.
regarding slipping, I can adjust the size of the mount. I can pull it a lot more than in the picture.
